if you want cheaper i got an 09 for sale but has aroud 920k will let you know i'm currently testing it its a 13 speed as well, if everything looks good ill let you know,
Replacing I-shift with manual transmission 10/13/18 ? Is it possible?
Discussion in 'Volvo Forum' started by Johny41, Aug 6, 2017.
Page 2 of 5
There available vilvo d13 trucks with 13speed just look on truckpaper for examlke this one
http://www.truckpaper.com/ListingsDetail/Detail.aspx?lp=TRK&OHID=17552797
It will be more simple to find truck already with 13 speed tranny. -
Thx,Nasriza! swapping transmission with manual seems to be serious work.
I know you guys have more choices, i'm searching the truck paper. I'm in Canada ,it's getting to expensive to buy a truck from US with this exchange rate, plus the import paperwork hassle, transport ,taxes. I purchased a truck from Houston Tx years ago, was too much headache until i got across the border and plated. -
They are out there i dont know how canada is a lot of the trucks i have seen from canada are usually auto's i dont know if that is what it is preffered up there.
It's a machine every thing breaks eventually. That being said. How many I shift transmissions are on the road? How many are properly maintained? How many actually fail. Most failures are from not maintaining the equipment. Can you maintain your equipment and it still fail? Sure it can but not as likely.
believe it or not most failures actually come from the #### leveling valve rod falling off and people not noticing also tows not diconnecting drivelines and weld trans together.
KB3MMX Thanks this. -
But the transmission itself is a manual gearbox. I understand it has a lot of electronics that control it, but these trucks have electronic controlling everything now days.
My 2015 T660 has a separate ecm for each door just for electric windows. My point is that there is nothing simple about any component on any truck built after the late 80's to early 90's. -
ya but ishift is not the same as eaton fuller auto its something completely different
Ok so of the two which one is more bullet proof?KB3MMX Thanks this.
I just watched this video, explains the dual clutch function in I-shift; but i'm still stubborn dweeb
into manual .
from time 03:00
Page 2 of 5
