Replacing sleeper airbag
Discussion in 'International Forum' started by TruckerPete1990, Oct 9, 2015.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,377
    Jul 16, 2012
    Bentonville Arkansas
    The sleeper airbag has a small leak. How do I replace it? How do I keep the sleeper lifted when I take it off? Should I replace that shock too? Should I replace both or just the one.
  3. RSQ20
    RSQ20 Medium Load Member
    Place a piece of lumber under cab, use a jack to lift and hold, replace bag... If the shocks have been on a long time, check and replace a required...
    ... Philip
  4. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    what kind of truck is this on cuz if its a prostar it's not as easy
  5. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    If its a Prostar better price that thing first. White's in NC quoted me 710.00 with fleet discount for one side.
  6. Cowtipper
    Cowtipper Light Load Member
    145
    144
    Aug 17, 2015
    I think on a Prostar, the shock is part of the unit...or at least it goes up thru the middle, so if it is a little tough to change, I'd change both.
    Have never changed one on a Prostar...on a Century it takes longer to find your jack then it does to replace it.
  7. TruckerPete1990
    8,623
    5,377
    Jul 16, 2012
    07 int 9400i each bag is 75.00 the problem is they are a big Assembly
  8. silver dollar
    silver dollar Medium Load Member
    481
    210
    Jan 31, 2009
    Central North Carolina
    I have the same problem. '02 9400i. I've already bought the bags, fittings, and air line just in case. But I cant figure if the bags are replace individually, or the entire leveling assembly has to be removed from the truck, then replaced.
    Where is HeavyD?
  9. woolybully35us
    woolybully35us Medium Load Member
    313
    550
    Mar 13, 2015
    ks
  10. woolybully35us
    313
    550
    Mar 13, 2015
    ks
    at the back of sleeper use a 2x4 an put between the rubber bumper an the frame to hold up the sleeper. then take the air lines off. unscrew the bags, then pry then the bag down. then put new ones on .it easy to replace . I would not replace the shock unless its leaking oil. I have a 9400i I've changed then twice
    silver dollar Thanks this.
  11. silver dollar
    481
    210
    Jan 31, 2009
    Ahh! They unscrew. I thought they did when I saw the threaded hole on the bottom. I asked the parts guy about this when bought the bags, but he couldn't tell me. He the same bag may be used in other applications, and he didn't know if mine were screw on or not.
    Should I be able to unscrew them by hand? It's tight under there.
