Replacing wastegate on 3406c turbo
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gambino1994, Apr 11, 2017.
  1. Gambino1994
    Gambino1994 Light Load Member
    187
    102
    Jan 22, 2009
    causing a situation
    3zj 425 horse. It has a wastegate turbo currently part #112-6918. In my research it's a garret gt75?? It seems to run pretty healthy, overhauled, fuel screws set, afrc turned to smoke a bit and I just went thru the aftercooler and all is good. I can get 21-22 max boost but if I pinch the line I can hit 30psi. Should I see that much difference in pinched vs open
    Oxbow Thanks this.
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Yes.
    21-22 psi is within spec.
    Dont pinch off the gate. It will not get you more power.
    Sounds like its all working as it should.
    If your egts are fine then leave it alone.
    Should be a garrett gt47 frame turbo if i recall.
    Oxbow and Gambino1994 Thank this.
  4. Oxbow
    Oxbow Road Train Member
    12,751
    131,813
    Nov 24, 2015
    I have a BW 177148 waste gated turbo on a 4MG, and I get 24 to 26 lbs. of boost, which is pretty close to what you get.
    Gambino1994 Thanks this.
  5. Gambino1994
    187
    102
    Jan 22, 2009
    causing a situation
    Did you have a wastegated turbo on your 4mg before the 177148 oxbow? What was your boost with the cat turbo I wonder? I was going to get that exact turbo but this one seems fine
    Oxbow Thanks this.
  6. Oxbow
    12,751
    131,813
    Nov 24, 2015
    Just the old stock turbo before. About 18 psi max with stock fuel settings - up to 27 or so if you turned the fuel screws out enough.
  7. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    177148 is one of the best options.
    The series of charger used is the generation before the GT series, it may be the same basic charger as a GT47 but likely older aero wheels.
    Oxbow Thanks this.
