Required to use anothers DOT#, Why?
Discussion in 'Questions From New Drivers' started by Independent51, Dec 27, 2011.
  1. Independent51
    Independent51 Bobtail Member
    15
    MA
    Hi, I'm new to this board, liked the layout so I joined.
    I have a couple of questions to do with DOT #'s and Signs on my truck. I am an independent trucking company - brand new.
    I have been offered to move materials for a local company as an Independent Contractor, they want me to put their signs on my truck and also work under their DOT#. I have my own DOT# and have explained this to them. There is no reason I can see to use their number or their signs. When I asked them why I should use their DOT# they could not explain why. Nor could they explain why I am to use their signs. They referred me to their NY office and I called but no answer, just voicemail so far.
    I understand there is a fine line between being an employee of a company and a Independent contractor.
    By agreeing to use their DOT# and signs it seems that would make me an employee, not an Independent.
    Can anyone shed any light on this situation? Has anyone come across this before?
  3. mgfg
    mgfg Road Train Member
    1,753
    626
    Mar 29, 2010
    What you are doing is what we used to refer to as "Trip Leasing". Nothing illegal or imoral about it, the carrier wants "their " trucks hauling their freight. You are just a contractor to them...not an employee.
  4. Independent51
    15
    MA
    I can understand that to a point. But, If I get an infraction using my DOT# while hauling for them, they would be held harmless, correct?
    If I use their number they would incur the hit on their rates.
    So why would they take that gamble.
    Also, It is my truck. If they deemed it to be theirs, Why wouldn't they be responsible for fuel and what not?
    They are contracting Owner Operators.
  5. the gambler
    the gambler Medium Load Member
    330
    245
    Feb 14, 2011
    Kentucky
    It's same as leasing onto a carrier like Landstar or Mercer. It sounds like they do not have a broker license. There for the can not broker you the load and have to do a trip lease or ". Temporary lease"
  6. Independent51
    15
    MA
    OK, You can see I'm new at this but want to cover all the angles. This "trip lease" or "temp lease", are you saying they will want to enter into a signed type of lease agreement to use my truck to their benefit?
  7. mgfg
    1,753
    626
    Mar 29, 2010
    A trip lease will spell out the term of the lease. They used to specify that they were for going from the agent, to the shipper and to the consignee. After that the lease was terminated unless you were doing round trip freight.
    There needs to be some documentation linking your truck and the plate on your truck to them as a carrier. No different than a lease between an O/O and a carrier (as was previously mentioned).
  8. Independent51
    15
    MA
    OK, got it. Thanks. I'll have to wait and see how they spell it out. It was good to be here, I've learned something. I'll be back again for sure.
