Reset My Dash still flashes code
Discussion in 'Peterbilt Forum' started by Pauly20, Mar 9, 2014.
  1. Pauly20
    Pauly20 Bobtail Member
    7
    Jeffersonville, NY
    I have a 2000 Pete with a 3406E and at first the light in the dash flashed a code 38 that the air temp intake manifold sensor was bad.. I changed that and still flashed the same code. I had to drain the system so I could fix air compressor and now its flashing 62 a low water level.. I changed that sensor also and it still flashes the 62.. Any ideas how to reset this so it clears the flashing light?
    Any help is help at this point
    Thanks in advance
    Paul
  3. mark2014
    mark2014 Bobtail Member
    4
    I would try to find someone with a laptop and Cat ET to try to clear out the faults.If that's not possible try disconnecting batteries for a few minutes .Honestly though getting it laptopped is the best .You may have other issues besides the two codes.
