Restarting Reefer after running it out of fuel
Discussion in 'Experienced Truckers' Advice' started by methane, Feb 3, 2013.
Page 2 of 4
best bet go to lowes get a pvc screw on cap drill hole for tire valve air up hit start button, will work every time
Homemade1959 Thanks this. -
Best bet is to fill it every time you get a chance to.
Cranky Yankee, joseph1135 and TRKRSHONEY Thank this. -
Look inside the right reefer door there is a nice big paint by number diagram. Unscrew this >, pump this >, don't do it again!!
It probably threw an alarm and you have to clear the code too. -
I have a real aversion to spending money on something until I have exhausted EVERY thing i could try first.
So, thinking about the "pressurize the tank" suggestion, I took my air hose which has a glad hand on one end and a air chuck on the other. I removed the air chuck, connected the glad hand to my emergency air glad hand and charged the system (holding most of the pressure by pressing my thumb over the open end of the hose). I then pressed the open end of the hose over the brass pressure relief valve on top of the reefer fuel tank, held it there listening to the air go into the fuel tank. I only held it there for about 1/2 second. Then tried to start the reefer again... No deal, but it did sputter once. So, I then held the air hose on the pressure relief valve again, this time until I could hear the pressure begin to build just slightly (about 3-5 seconds). Turned the reefer on again, it tried to start, sputtering again, but no full start. Looking at the primer pumped with the feed and return lines going into it, I thought "The fuel is still not flowing because air is still in the line. How do I let the air out?"
I loosened the return fuel line and the pressure from the tank pushed the air and fuel up through the feed line which purged the air! Turned the unit on and BINGO, the engine cranked, sputtered twice and roared to life!! Wahoo!
Thanks guys for getting my brain smokin and figuring a way to get the unit running without spending a penny on it. -
Yeah, alarms telling me the engine stopped... no kidding? LOL
My reefer is an '05, the instructions and alarm code list are both long gone. Got it working now, ThanksCondoCruiser Thanks this. -
AMEN!! Wont happen again, I assure you.
I have loosen the lines at the head too. Just as long as you give it a place for the air to escape because the injectors are closed and won't let the air out.
Glad you got it running. You'll be fueling at a half tank now!
Page 2 of 4
