Restriction "no tractor trailer" on license since moving?
Discussion in 'Questions From New Drivers' started by Newdriver813, Sep 23, 2025.
  1. Newdriver813
    Newdriver813 Light Load Member
    88
    124
    Jan 8, 2023
    So I was talking to a company and they said I had a restriction on my license, “no tractor trailer”. I’ve been driving over two years can you guys help me understand how I can fix this… maybe someone made an error when I switched from NV to FL…
    77fib77 and nextgentrucker Thank this.
  3. tscottme
    tscottme Road Train Member
    Call the driver license office, whatever the state that issues your driver's license calls it, and ask them.
  4. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    934
    1,787
    Dec 15, 2021
    What kind of truck did you use when you tested?If you used a dump truck pulling a tilt deck trailer,using a pintle hook,you get the O restriction.You need to test in a regular tractor with a fifth wheel.
  5. Walk Among Us
    Walk Among Us Heavy Load Member
    930
    5,111
    Mar 3, 2025
    Fort Worth, TX
    No big deal. You just can't drive a semi.:)
    77fib77, Siinman, tscottme and 2 others Thank this.
  6. BrothaTrucka513
    BrothaTrucka513 Medium Load Member
    359
    642
    Aug 30, 2020
    Demand that the reps at your local DMV Branch stop trolling and give you your "REAL LICENSE". They should fall in line shortly after you display cajones verbally.
    77fib77 Thanks this.
  7. Newdriver813
    88
    124
    Jan 8, 2023
    I tested in a semi truck, this is crazy.
    77fib77, Siinman and Magoo1968 Thank this.
  8. North Pole Nightmare
    934
    1,787
    Dec 15, 2021
    Check with the Florida DMV to find out how that happened.
  9. North Pole Nightmare
    934
    1,787
    Dec 15, 2021
    Errors happen a lot.Just today I got sent in for a random,had my old driver's license on the paperwork for the testing.That got corrected fast.I changed license to a new state last December.
    77fib77 and Siinman Thank this.
  10. tscottme
    Did you CAREFULLY examine your CDL at the counter in the DMV office? What endorsements are showing on your physical CDL card now?
  11. Lazer
    Lazer Road Train Member
    1,812
    2,894
    Jan 22, 2017
    Delete
    Reason for edit: delete
