Retreads on the front axle of a spread axle flatbed?
Discussion in 'Questions From New Drivers' started by WadeH, Feb 26, 2021.
  1. WadeH
    WadeH Bobtail Member
    43
    14
    Apr 1, 2019
    I drive for a manufacturing company that has plants scattered across the US. A driver from one of our other plants told me that it was not permitted to use retread tires on the front axle of a spread axle trailer because of the severe scuffing on the front axle tires when turning. He said that because the scuffing causes the tread to separate from the casing it is a violation to run with caps on the front axle.
    True or BS?
  3. Diesel Dave
    9,245
    29,520
    Jan 20, 2010
    Hesperia, Ca.
    B.S.
    singlescrewshaker Thanks this.
  4. Hyweighman
    Hyweighman Medium Load Member
    517
    659
    Dec 29, 2011
    Pensacola, FL
  5. Bean Jr.
    Bean Jr. Road Train Member
    5,539
    9,876
    Mar 30, 2014
    It's not true. However, my carrier's policy is to install only virgin tires on the front axle of a spread.
  6. 201
    201 Road Train Member
    12,621
    25,905
    Apr 16, 2014
    high plains colorado
    Never had any luck with recaps, and pulling RR trailers, I went through my fair share. If you must, however, have an axle that lifts.
  7. Capacity
    Capacity Road Train Member
    1,499
    3,119
    Jul 28, 2019
    Neenah Wi
    BS , turnip truck style.
  8. abyliks
    abyliks Road Train Member
    3,997
    9,395
    May 2, 2010
    ludlow MA
    Not illegal but not smart either
  9. wis bang
    wis bang Road Train Member
    3,428
    4,066
    Jan 12, 2011
    Levittown, PA
    Waaaaay back in Bias tire days, we had 'full' caps just for the front axle on a spread axle along with strong warnings to not use a regular cap on there...
    Radials could/should be different.
  10. Coal Region Deplorable
    Coal Region Deplorable Light Load Member
    Old wives tale, just like the guys that tried to say it's illegal to run recaps on a steering axle.
    Most truck drivers aren't too bright, never crack a book, and rely on some kind of whisper down the lane method of attempting to know rules and regulations.
    No is it a good idea to run them there? Probably not,. Have I done it? Yeah sure I've done it,sometimes you blow tires and that's all you have back at the shop. Nothing illegal about it though
  11. Moose1958
    Moose1958 Road Train Member
    15,257
    33,813
    Dec 17, 2010
    Williesburg, Virignia
    I agree, and the reason for this confusion is a misreading of 393.75.
    §393.75 Tires.
    (a) No motor vehicle shall be operated on any tire that—
    (1) Has body ply or belt material exposed through the tread or sidewall,
    (2) Has any tread or sidewall separation,
    (3) Is flat or has an audible leak, or
    (4) Has a cut to the extent that the ply or belt material is exposed.
    (b) Any tire on the front wheels of a bus, truck, or truck tractor shall have a tread groove pattern depth of at least 4⁄32 of an inch when measured at any point on a major tread groove. The measurements shall not be made where tie bars, humps, or fillets are located.
    (c) Except as provided in paragraph (b) of this section, tires shall have a tread groove pattern depth of at least 2⁄32 of an inch when measured in a major tread groove. The measurement shall not be made where tie bars, humps or fillets are located.
    (d) No bus shall be operated with regrooved, recapped or retreaded tires on the front wheels.
    (e) A regrooved tire with a load-carrying capacity equal to or greater than 2,232 kg (4,920 pounds) shall not be used on the front wheels of any truck or truck tractor.
    (f) No motor vehicle may be operated with speed-restricted tires labeled with a maximum speed of 55 mph or less in accordance with S6.5(e) of FMVSS No. 119 at speeds that exceed the rated limit of the tire.
