truck is a 1986 Pete 359.
NYS Trooper gave me a inspection last week and wrote me up for “no reverse lamp”. The truck does not have a reverse lamp.
I spoke to Knoxville TN Pete where the truck was purchased new and they say the truck wasn’t built with a reverse lamp.
I contacted the service dept at The Pete dealer in Utica NY and asked if the 1986 model year required a reverse lamp. He said the NY state safety insp rules state all vehicles mfg after 1969 require at least one reverse lamp.
I don’t want to install one if I don’t have to. What gives?
Reverse lamp
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rank, May 9, 2018.
Page 1 of 4
well then you better cough up the money for that violation
snowman_w900 and Tb0n3 Thank this. -
Any rule stating that reverse can’t be on a switch not tied to transmission ?? If not wiring in a simple back up light would save tons of time... and I agree that’s a BS ticket since you have a trailer behind you
rank, gentleroger, snowman_w900 and 2 others Thank this.
In Canada, anything built after 1971 was required to have a reverse light.
rank and snowman_w900 Thank this. -
the current rule (393.11) says the light must come on when the vehicle is put in reverse. To me that means tied to the trans somehow but as long as I don’t forget to flip the toggle on the shifter he wouldn’t know.
I was really trying to find out if anyone here knew when that reverse lamp law came into effect. Or if someone has a rule book from 1986 lol. Based on what Utica Peterbilt told me above it looks like I have to install oneLast edited: May 9, 2018
As far as Pete not showing them installed, that doesn't mean they weren't required, it's not uncommon if the truck was built for a specific application that required finishing by another company. Our car haulers are ordered with no lights at all on the rear of the tractor, no 5th wheel, not even a 7-way plug. All that is finished at Cottrell when they build the head rack, so Pete has no records of those parts.
Edit: We use the oval version of these on our trucks. The factory Cottrell reverse lights are mounted behind a hydraulic cylinder and are pretty useless.
rank Thanks this. -
nys requires lamp and audible alarm for reverse. dont matter if your out of state if your in NY your required to be in regulation. doesnt matter of your out of state you WILL get a tinted window violation if you have your door glass tinted
rank Thanks this. -
Page 1 of 4
