RFX-75 add on to Cobra 29LX-- will it work on the CB jacks?
Discussion in 'CB Radio Forum' started by maniac373, Nov 29, 2013.
  1. maniac373
    maniac373 Bobtail Member
    4
    Hello, I own a Cobra 29LX. It has a mild peak and tune now.
    I was thinking of having a RFX-75 add on power kit added to my radio.
    (To those who don't know, it bumps the peak power of the radio up to around 75-80w.)
    As of now, I have not had this done to my radio...
    I drive a company truck, with cb jacks on the dash.
    I was wondering-- will this radio work on the cb jacks without blowing the 10a fuse?
    Thanks in advance ...
  3. Ridgeline
    22,136
    113,472
    They are not meant to be used for a radio with an amp.
  4. maniac373
    4
    I'm in a company truck.
    I won't be running an amplifier at all. Just the radio alone.
    The rfx kit is an add on kit on the radio itself.
  5. Rat
    Rat Road Train Member
    Yes it will work. But go through the setup and make sure everything is tight first.
  6. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    It's gonna draw 10-13 amps with the RFX on board, so yeah you might blow a fuse.
  7. Ridgeline
    22,136
    113,472
    Binding posts in these trucks are cheap chinese made things, they have a rating about 10 amps at the most, you can melt them with 15 - I have.
  8. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    Sure it works! For at least a little while.
    The idea behind the extra power is to be heard over longer distance, if you key up too long its self defeating and your fuse melts... I like big radios, but hate big/long talkers. You have perfect setup! (You talk too long you burn it up and I don't have to listen, you talk short and everyone hears simple NB rollin @ ## Mile mark.) :biggrin_25525:
  9. JCordle
    JCordle Bobtail Member
    38
    14
    Nov 4, 2013
    I have my radio with a rfx-75 hooked up to them.
    I run a 5watt fuse replace it about once a week!
    Until I can run some bigger wires and better plugs
    To let it sing. as long as I keep my messages short it's fine!
  10. Rat
    I ran 8 gauge wire from the battery to the posts in my last pete then ran my Connex 4600 turbo off the posts and never melted them.
  11. Big_m
    Big_m Heavy Load Member
    881
    265
    Oct 13, 2009
    Central Maryland
    Why not try 7amp fuse?
