RG58 / PL-259 Connection
Discussion in 'CB Radio Forum' started by nashville rookie, Aug 13, 2008.
  1. nashville rookie
    nashville rookie Bobtail Member
    Nashville, TN
    I need to crimp on a PL-259 connection to RG58 coaxial. What size die do I need to use in a crimp tool to get it done? Thanks!
  3. Otter
    Otter Light Load Member
    298
    212
    Mar 16, 2008
    Milton, VT.
    I wouldn't use a crimp on PL259 or RG58 on any radio I own. Have someone put a solder type PL259 on for you, you may be stuck with RG58 coax in the truck, and it can be a real pain in the ##### to change.
    nashville rookie Thanks this.
  4. nashville rookie
    Nashville, TN
    Do you recommend RG8 vs. RG58? Can a CB shop sodder on a PL-259 connection? Thanks for your guidance!
  5. thetez
    thetez Medium Load Member
    380
    24
    Jul 10, 2006
    rg58
    and yes a shop will solder it on, but why spend that money.... their are a bunch of type that dont need to be soldered. Their are a few at radioshack that all you need to do is strip the coax for an inch and tighten a screw down, and your done... check radioshack out for a few other types on connections, or use the one you need to crimp and if you ever need to take it out cut the connector off.
  6. walleye
    walleye Road Train Member
    3,028
    4,306
    Aug 21, 2007
    Land of Cheese
    I don't know about anybody else, But I try to solder ALL electrical connections. There are times when I just don't have the room or time, but I almost always go back latter and fix it, soldered connections are much less prone to problems.
  7. thetez
    380
    24
    Jul 10, 2006
    i am the same way, but i have used the solderless tips, they have never given me a problem. i have it installed on one end of my cable, its nice, you strip the outer shield, slide the connector over and tighten a screw which digs past the first 2 layers and hits the center copper core. they work well and are very easy.
  8. nashville rookie
    Nashville, TN
    After reviewing numerous antennas and their performance, I decided to go with a K30 magnet mount antenna vs. a fiberglass whip on my spare tire carrier. I understand that the ground plane available on your roof can greatly improve performance. Now I just need to figure out how to tune the thing!
  9. Otter
    298
    212
    Mar 16, 2008
    Milton, VT.
    RG8X mini form with a stranded centre conductor is the best coax most of us can afford for mobile installation. Solder on PL259 is the right way to go, and yes a CB shop should be able to put one on for a couple of bucks.
