RGN trailer rollers (to roll the neck onto the truck)?
Discussion in 'Flatbed Trucking Forum' started by ichudov, Nov 12, 2017.
  1. ichudov
    ichudov Heavy Load Member
    742
    641
    Mar 14, 2012
    Berkeley, IL
    I bought a mechanical RGN trailer. I am trying to add a ramp to the truck and start using it.
    It has rollers that roll up the truck frame when I pick up the trailer. The problem is that these rollers are in poor condition and do not rotate easily.
    I would like to torch cut them out and replace with new rollers.
    The problem is, when I search for those things online, I am not finding much. I suspect that I search for the wrong term or name. How would I find them for sale?
  3. johndeere4020
    8,522
    119,291
    Jan 1, 2010
    Call the manufacturer and give them the vin.
  4. Oxbow
    Oxbow Road Train Member
    12,662
    130,555
    Nov 24, 2015
    About the only other choice is to take the roller and/or trailer to a local machine shop and have them made. Not sure if this would save any over just calling the trailer manufacturer though.
    SAR, ichudov and 4mer trucker Thank this.
  5. ichudov
    742
    641
    Mar 14, 2012
    Berkeley, IL
    but what are those rollers called in proper trade terms?
  6. johndeere4020
    8,522
    119,291
    Jan 1, 2010
    Rollers
    truckdad, stwik, SAR and 5 others Thank this.
  7. Oxbow
    12,662
    130,555
    Nov 24, 2015
    Mechanical detach neck rollers maybe?
    stwik, SAR, ichudov and 1 other person Thank this.
  8. Hegemeister
    Hegemeister Road Train Member
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Some people don't realize that the rollers have grease fittings and use them for years without greasing.
    Can you try to clean the ones you have now and apply fresh grease?
    ichudov and Oxbow Thank this.
  9. ichudov
    742
    641
    Mar 14, 2012
    Berkeley, IL
    One of them has a grease fitting that is broken. Another already has no grease fitting whatsoever and clearly was somehow rewelded or otherwise repaired, which removed the grease fitting.
    Looking around, I recalled that rolloff containers have rollers, looked for rolloff rollers, and found some "nose rollers" such as "4x6 nose rollers". Clearly heavy duty rollers.
    Making brackets for those, torching old rollfers off, and welding new rollers on, is not a problem for me.
    So, if you guys think that 4x6 rollers are acceptable, I will simply buy those and be done with it.
    Oxbow Thanks this.
  10. johndeere4020
    8,522
    119,291
    Jan 1, 2010
    Why not call the manufacturer like I suggested? Might even get them cheaper.
    SAR, Oxbow, Ruthless and 1 other person Thank this.
  11. ichudov
    742
    641
    Mar 14, 2012
    Berkeley, IL
    I will definitely call Trailking tomorrow, that's a great idea for sure.
    Oxbow Thanks this.
