Ride height leveler leaks through exhaust port
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by HoneyBadger67, Oct 17, 2023.
  1. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    T660 with AG380 suspension
    As stated, the leveling valve leaks from exhaust port regardless of whether I'm being unloaded or not. I've replaced the valve twice trying to fix the problem. Kenworth just says, "sometimes they do that".... Anyway, my question is, is there another air valve somewhere that works with the ride height valve that might cause this problem? Or...did I not install it correctly, even though I just swapped lines from one valve to the other? How might I fix this issue?
  3. OLDSKOOLERnWV
    18,255
    274,851
    I’ve replaced the leveling valve on my truck a couple times just to see the air bags flat the next morning.
    The valve on my flatbed trailer will keep the air bags inflated for weeks with no air loss, but it is a different style valve too….
  4. Short Fuse EOD
    2,772
    8,647
    Jul 29, 2015
    Midwest
    I go thru valves every now and then. Especially with air ride all the way around. They do allot of work. They go bad. Maybe TRP vs. OEM. I haven’t replaced the TRP ones yet..
  5. Cdemars316
    Cdemars316 Medium Load Member
    683
    3,725
    Nov 10, 2018
    Hmm funny I've been through two of the trip ones in like 6 months now
    Rideandrepair and HoneyBadger67 Thank this.
  6. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    So, it's not just me, then. Speedco was going to fail my DOT inspection for it, even though I maintain ride height until I shut off the truck
    KB3MMX and Rideandrepair Thank this.
  7. elliott
    elliott Light Load Member
    102
    30
    Sep 3, 2007
    I took apart an old leveling valve that I pulled off a trailer and it had gunk and debris in it. I think the inside of the tanks can corrode and send tiny flakes into the valve, along with moisture and oil. They're pretty easy to clean and rebuild, though; just a couple of o-rings inside.
    KB3MMX and HoneyBadger67 Thank this.
  8. Marktiet
    Marktiet Bobtail Member
    Did you check it with some good mechanics????
  9. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    That might be why it's in the mechanics forum
    KB3MMX Thanks this.
  10. 062
    062 Road Train Member
    6,201
    33,404
    Oct 20, 2013
    Have you played with the arm to see if there’s a spot where it stops leaking?
    Quality control isn’t what it used to be.
    @Goodysnap
  11. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    If I just wiggle it, front to back, it stops
    KB3MMX Thanks this.
