Ride quality: walking axle vs. single
Discussion in 'Questions From New Drivers' started by gkmissingca, May 2, 2017.
  1. gkmissingca
    gkmissingca Light Load Member
    102
    29
    Feb 18, 2017
    I'm in the process of building a truck specificly for hauling RV's. Weight wise I know only a single axle is necessary. But the rig I'm getting has a walking beam. Return loads are probably going to be similar weights
    Option 1: Keep walking beam and run 4 single tires (I think. If I ran 12r22.5's on 12.25 super singles x4 would still have enough to remain legal). This would be a lot less cost/head ache/work but more drag/weight. Would make the second axle a dummy axle only.
    Convert to single axle: More cost/less weight/less drag but new issues with frame height (critical for hauling RV's. Will be getting dovetail flatbed for trailers). Would retain dual wheels on the axle.
    Another aspect is ride quality. I'm already considering removing at least the first two leaves. But does the geometry of a walking beam give a little better ride quality?
    Note: I'm a cdl driver for a county job so my literal knowledge isn't too bad, but real world knowledge is limited.
    thankyou in advance.
  3. AModelCat
    156,496
    I'm doing to same kind of thing, only for personal use though. First thing I did on mine was chop the walking beams out and throw them straight into the scrap bin. Diffs and all. My truck will never have enough weight on it to make it ride decent.
    If you have the Hendrickson extended leaf taking a couple leaves out won't make much difference since it only rides on the top leaf when empty anyways.
    Bean Jr. Thanks this.
  4. Ridgeline
    22,261
    114,724
    What do you mean hauling RVs?
    Like a haul and tow?
  5. gkmissingca
    102
    29
    Feb 18, 2017
    Ridgeline-yes, Haul and tow.
  6. crb
    crb Road Train Member
    1,676
    1,374
    Dec 1, 2009
    USA
    Almost every haul tow I've seen the single axles. I would think single acle would be advantageous for dovetail and load height.
  7. crb
    1,676
    1,374
    Dec 1, 2009
    USA
  8. gkmissingca
    102
    29
    Feb 18, 2017
    I plan on using shipshe to build the flatbed. But looking at the walking axle, I'm not sure it would be as simple as reusing that axle. The mounts are kinda different, plus the cost of redoing a driveshaft is just more money. Removing the second driveshaft and using stub float axles would probably be free.
  9. okiedokie
    okiedokie Road Train Member
    11,902
    87,302
    Jun 13, 2011
    PNWET
    Empty truck with walking beam suspension.
    Bean Jr. and AModelCat Thank this.
  10. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,132
    Mar 5, 2016
    White County, Arkansas
    Walking Beam? Been there done that.
    You don't want it. *Slaps... are you crazy? That single axle will stuff a RV into a half acre. That poor empty walking beam with no weight will absorb 400 more acres of turning and pullups before you finally line er up.
    Walking beams are best being loaded and on very bad terrain, as in extremely bad terrain.
    And you *Slaps again... want to put 4 heavy super singles onto those walking beams? Those #### axles will go try peeling those supers right off. Rip.
    Get the single like everyone else in the RV towing business. They are not that heavy.
    crb Thanks this.
  11. gkmissingca
    102
    29
    Feb 18, 2017
