Wasn't sure where to post this... 2000 FRL classic.
When all the lights are off the right turn signal turns on basically every light almost like hazards.
When the lights are on the right signal works on some lights and dims some lights where as the left works just fine... Not sure where to begin...
Edit: I did just installed a 3k watt inverter. Is it possible I messed the negative wire to cause this? I put the negative on the battery vs putting it on the chassis and haven't connected a ground wire to it yet.
As is the inverter needs positive, negative AND a ground but only positive and neg are attached
Right signal dim
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by MKT, Jun 18, 2017.
