Does anyone use the right weight onboard scale systems or any other kind of onboard scale system? If so I'd like to get your thoughts on them as far as their accuracy, durability and overall if you're satisfied with them. Those 9 and 10 dollar scale tickets add up...... Thanks
Right Weight Scale Systems
Discussion in 'Ask An Owner Operator' started by jellybean, Sep 17, 2011.
I have a simple air pressure guage from the drives to a dash guage. Once I got used to it, I normally don't scale unless the weight is getting me near 79k gross.
jellybean Thanks this. -
www.airweigh.com
But as mentioned above, all my trucks had a tractor guage, trailer guages too. Including my lowbeds.
Here you go.
http://www.air-weighscales.com/jellybean Thanks this. -
Simple air pressure gauges work just fine...no need for the fancy expensive ones. Once you know how much air pressure the gauges indicate for a max legal load, you can limit your pay-scale visits to only those loads that have you right up close to maxing out when you know you'll have to cross a state scale.
My truck has a dual needle gauge, and a line running back to the trailer (quick-connect on the front of the trailer for the trailer suspension air). It is pretty rare that I pay to weigh my truck...maybe 2-3 times per year. -
Here is the one for the 30k.
Here is the one for the 25k
Here is the one for the 23k
It's the same for the tractor, I know that 60psi is 34k on the drives on all of my KW's with 8bag suspension. Only needed to verify it once.
Print the correct one off and save yourself the money. -
Kenworth suspension.jellybean Thanks this. -
I use the Right Weigh load scales. Pretty accurate if on the level. I don't like to run without them. Money well spent.
Right Weigh Inc. and Dumptrailer Thank this.
