Rim offset for wide steer tires on a 379L
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jimmy the cat, Dec 29, 2011.
  1. jimmy the cat
    jimmy the cat Bobtail Member
    12
    Dec 29, 2011
    I want to put 385-65R 22.5 steering tires on my 04 379L Pete. Can any one help me with part # for the correct rim or what offset I would need. I want polished alluminum wheels. Thanks the Cat
  3. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I would just turn the wheels easch way and measure what you have for clearence. When I put 425's on mine I believe I got a 3" offset. The idle arm is probably where you are going to rub first.
  4. Licensed to kill
    Licensed to kill Heavy Load Member
    830
    2,435
    Dec 31, 2010
    Alberta
    Any truck wrecker will know what offset you need for a 379 Pete. However, something to consider, if you have a 12,000 lb axle, the bearings are too small and may not hold up with the wide steer tires.
