Rino lining on trailer
Discussion in 'Flatbed Trucking Forum' started by m16ty, Jan 9, 2017.
  1. m16ty
    m16ty Road Train Member
    2,274
    4,963
    Jan 22, 2016
    We just got a new 2016 Landoll. On the bed, about 2' from the end, there is a piece of flat metal that forms the approach plate. When wet, wheeled equipment has trouble spinning out on the slick metal. I've been contemplating putting Rino lining on it but wonder if it will hold up. We only haul wheeled equipment on this trailer, no tracks.
    We've got a older Trail King traveling axle trailer that we welded cross hatches on the approach plate but I have trouble grinding off the powder coat paint and doing that to this new trailer. Does anybody have any thoughts about the durability of Rino lining in this application?
    snowman_w900 and MJ1657 Thank this.
  3. bigguns
    bigguns Road Train Member
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    You better check the grip factor before trying the Rhino lining.
  4. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    When Rhino lining is dry it would probably help a bit. If it's wet I do not believe it would be much help.
    4mer trucker and snowman_w900 Thank this.
  5. *Five-0*
    *Five-0* Light Load Member
    207
    257
    Jun 21, 2014
    Hey...I'm over here!
    Google "non slip paint for metal surfaces" - you should find something on there that is designed to accomplish what you need to do.
    brian991219 Thanks this.
  6. m16ty
    2,274
    4,963
    Jan 22, 2016
    Well that wouldn't help much. I don't have any problems now when it's dry
    MJ1657 Thanks this.
  7. dngrous_dime
    dngrous_dime Road Train Member
    3,150
    5,765
    Jan 28, 2014
    Lansing area, MI
    Call up a Line X dealer, and see if they have a textured medium they can add...
  8. cke
    cke Road Train Member
    6,061
    74,686
    Aug 4, 2013
    Colfax Wi
    Weld expanded metal to it and be done with it
    Chewy352 Thanks this.
  9. wileyjd
    wileyjd Bobtail Member
    15
    81
    Apr 29, 2013
    On our Farm trailers we did line X and added sand to the product it works great no slip and holds up great did the trailer about 5 years ago and no problems with it coming off
  10. noluck
    noluck Road Train Member
    1,616
    11,683
    Jun 10, 2011
    greenville,sc
    There is non slip paint that has something kinda like sand that would work. It may even be sand
  11. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Auto parts stores sell roll on bed liner, i experimented putting in on my deck. But i drag pallets ect.. across every day. So it gouged up quick. I used a brush to go for a smooth finish, they have rollers that give texture for traction. It will definitely work. Just do proper prep.
