Road test on a 10 speed manual transmission - very rusty
Discussion in 'Questions From New Drivers' started by rolldice25, Dec 7, 2022.
  1. rolldice25
    rolldice25 Bobtail Member
    17
    28
    Jul 26, 2022
    I am hoping to get a job with a company that uses manual trucks. I haven't driven a manual since my DMV test early this year. Furthermore, the truck I learned on was a 7 speed. Is there anything I should do to prepare for the road test?
    The truck I learned on was pretty janky. Non synchronized Clutch, etc. How hard is it to shift in a halfway decent manual semi truck?
    OLDSKOOLERnWV and tscottme Thank this.
  3. Allow Me.
    10,724
    12,418
    May 28, 2009
    Rancho Mirage, Ca.
    Easy as pie.......
    tscottme Thanks this.
  4. Numb
    Numb Crusty Curmudgeon
    4,224
    9,908
    Jan 30, 2012
    Charlotte, N.Carolina
    no syncros is what a truck tranny is.
    okiedokie and tscottme Thank this.
  5. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    950
    1,838
    Dec 15, 2021
    Going from 5th to 6th gear gets me sometimes if I'm used to driving something else.
    Concorde and Numb Thank this.
  6. tscottme
    tscottme Road Train Member
    By the second day you will be about 90% squared away. I didn't know ANY semi-trucks had synchronized transmissions. Just drive and shift as slowly as you need to. You will probably miss a shift and have more trouble downshifting than upshifting. That applies to veterans and newbies. Just remember to only use as much clutch as necessary to slip into/out of gear. You don't press the clutch to the floor except when stopped. EVERY newbie presses the clutch TOO DEEP and that often activates the clutch brake which causes RPMs to drop quickly which makes getting into gear much harder and you will grind. Try pressing the clutch no more than 1/3 of the of the way down once you are moving at all. Don't psych yourself into unnecessary anxiety. Do the best you can and you will rapidly improve.
    nredfor88 and Numb Thank this.
  7. OLDSKOOLERnWV
    18,887
    284,663
    Use to drive a 1981 Cabover Freightliner with a 7 speed many years ago, didn’t care for it. Been better with a 1241D Spicer setting behind the 7….
  8. okiedokie
    okiedokie Road Train Member
    13,340
    103,793
    Jun 13, 2011
    PNWET
    CF line haul truck?
    OLDSKOOLERnWV Thanks this.
  9. OLDSKOOLERnWV
    18,887
    284,663
    No Sir, it was one of Pops trucks at Machinery Hauling in Kenova WV. Heck of a nice paint job just a lousy drive train with the 7 and a Formula 300.
    Last I seen of it, it was in 3 pieces, being winched out from below Sandstone mountain in WV. Driver said he rode it to the bottom, pretty sure he was stretching it….
    okiedokie Thanks this.
  10. MAMservices
    MAMservices Medium Load Member
    554
    3,975
    Aug 9, 2021
    Don’t think they had but three gauges in them either.
  11. okiedokie
    13,340
    103,793
    Jun 13, 2011
    PNWET
    Reminds of those 9 spds in a COE.
