Roadside Blitz ‘23 Common reasons for ABS Light
Discussion in 'Experienced Truckers' Advice' started by 4wayflashers, May 2, 2023.
  1. 4wayflashers
    4wayflashers Road Train Member
    1,080
    1,246
    Mar 14, 2014
    Honestly, it’s become such a frequent issue that I have just ignored the glowing light on the back of the trailers. I have even convinced myself that it’s not required for it to be working correctly after many years of ignoring it. Well this years roadcheck (May 16th - 18th) is the focus will be abs malfunction and cargo Securement. 2 issues that is difficult for a driver to be 100% to the t on.
    What do you guys know about common issues with ABS? Is there anything a driver can do, short of bringing his trailer in to the shop?
    When I was a brand new CDL I would chase down any and all little things religiously and if I remember correctly, I think sometimes I could get the light to go out by unplugging and replugging the pigtail after a bit. Any other tips a driver can try if he’s out of gum and that light is a glowing?
    Also probably a good idea to make sure someone before you didnt cut the wire because this coming roadside blitz is sure to get some unsuspecting drivers with a cut ABS malfunction light.
    gentleroger and Kyle G. Thank this.
  3. tscottme
    tscottme Road Train Member
    If the trailer has ABS installed, it must be working to pass a DOT inspection. When you start the truck while connected to a trailer the ABS light should briefly light and then extinguish. If it stays on you need an ABS repair on the truck or trailer. For the commenters later, nobody is asking if you feel confident driving without a functioning ABS system, and explaining how many decades the industry didn't have ABS and things worked OK does not exempt the person making the comment from an inspection violation. Busting the light so it is always off will not get a clean inspection report.
  4. drvrtech77
    drvrtech77 Road Train Member
    15,866
    156,928
    Mar 20, 2010
    I wonder how many flatbedders who routinely try to shortcut their way through load securement will get busted during this 72 hour deal?
  5. Big Road Skateboard
    7,543
    43,264
    May 2, 2021
    Sensors out of adjustment (often loose wheel bearings) and bad connections/broken sensor leads most common.
    It's also one og tge simplest systems to understand, if not interfaced with another ECU.
    And I prefer my ABS working, though I did install a switchbto cut ABS power to trailer. Turn it off on snow and ice
  6. silverspur
    silverspur Road Train Member
    1,820
    8,585
    Sep 26, 2012
    "Turn the key to the on position and let's see if the ABS light is working, "
    First thing the the inspector asked me to do in Virginia, I-81 NB mm150.
    D.Tibbitt, KB3MMX, wis bang and 2 others Thank this.
  7. Diesel Dave
    9,949
    34,991
    Jan 20, 2010
    Hesperia, Ca.
    Whatsoever do you mean ?:rolleyes: Do you mean instead of feeding the whole strap thru the winch, we fold it and feed it thru the first slot only and fold the rest ? :eek: Now, whoever in there right minds would do such a thing. :cool:
    4wayflashers and drvrtech77 Thank this.
  8. mtoo
    mtoo Road Train Member
    1,942
    4,529
    Jan 15, 2011
    Retired on bended knee
    Avoid the aggravation and take the week off. Do some maintenance on the ol girl
    nikmirbre, Cattleman84, KB3MMX and 2 others Thank this.
  9. drvrtech77
    15,866
    156,928
    Mar 20, 2010
    Doesn’t work so much anymore… The last few years they’ve done more inspections on the weekend before and the weekend after then the week of the event because they’ve apparently caught on
    Accidental Trucker Thanks this.
  10. DUNE-T
    DUNE-T Road Train Member
    7,085
    17,266
    May 10, 2015
    Detroit, MI
    I have trying to find the issue on my trailer for like a year, sometimes it works fine, sometimes that stupid light turns on on every bump, sometimes it was always on. Finally last week found a corroded wire, repaired it, but started acting funny again few days later. Then another repair and then the 3rd one. Finally got home and replaced the whole darn thing on Saturday
  11. Long FLD
    Long FLD Road Train Member
    13,242
    55,713
    Mar 4, 2015
    Oregon would look through the center of your winch and make sure they were laced all the way through.
