Rookie LTL, should I go OTR?
Discussion in 'Questions From New Drivers' started by coastietruckin', May 16, 2018.
  1. coastietruckin'
    coastietruckin' Light Load Member
    269
    148
    Dec 28, 2015
    Southern NJ
    I'm a brand new driver with no exp. Working on my 2nd week of LTL. Needless to say, there is A LOT to learn. My trainer has been not so helpful at times, and I've felt like I'm drowning under the pressure of getting the job done, let alone the fact that I'm trying to learn how to safely run a rig down the road and in the yard. I nearly resigned today because of an incident in the yard and my trainer had totally walked away from me and I had to recieve help from another driver.
    What would you experienced guys do in my situation? Stick it out or go otr with a training company to get more experience first? My terminal manager wants to keep me onboard and said I will get as much training time as I'll need before they set me off on my own. But obviously, I want to make sure that I remain safe on my job, so I'm trying to balance taking on a high pressure job with remaining safe as a new driver. I think I'm going to just proceed at my own pace until I get my feet under me. Just wanted to throw this situation out to the experienced guys on the board and see what ya'll think. What would you do as a rookie in my situation?
    bentstrider83 Thanks this.
  3. Chinatown
    Chinatown Road Train Member
    74,952
    170,834
    Aug 28, 2011
    Henderson, NV & Orient
    Stick it out where you are. Some of us love OTR, but it's not for everyone.
    bentstrider83, stwik, Woodys and 6 others Thank this.
  4. Buckeye 60
    Buckeye 60 Road Train Member
    1,229
    1,269
    Apr 19, 2018
    ltl gets you a lot better experience than otr .... but a lot of companies like a year of otr experience ..... so if you are getting to at least 3 states stay in ltl (that would be considered over the road) if not I would think about changing ... hopefully stayin with same company .... finish training in ltl anyways. .. doesn't look good to switch companies very often .... but I have a couple of trucks and hire drivers and someone told me they were with cr England for 4 years I would figure they were a moron ...
  5. coastietruckin'
    269
    148
    Dec 28, 2015
    Southern NJ
    I can put in for a linehaul gig after I complete my training and get a few months under my belt.
    Bean Jr. Thanks this.
  6. Puppage
    Puppage Road Train Member
    4,263
    7,370
    Aug 2, 2012
    Connecticut
    Can’t you request a new trainer? That sounds like the big issue here....bad trainer. Best of luck to you.
    JReding, Bean Jr. and coastietruckin' Thank this.
  7. coastietruckin'
    269
    148
    Dec 28, 2015
    Southern NJ
    Thanks, Puppage. Thats what my TM said as well and I'll be starting with a new trainer tomorrow.
    JReding and Bean Jr. Thank this.
  8. TripleSix
    129,827
    Stick it out is the right answer. If you jump ship, you're only postponing things. Your next trainer at the next company may be exactly like the one you have now.
    Now, where is it that you are struggling the most? What were you doing when the trainer walked away?
    What help did you need from the other driver? Before he walked away, what exactly did the trainer say to you?
    "What difference does that make, Six? I needed help and he walked away."
    Depends on what you were working on. Some things he may want you to figure out on your own. Obviously, you two have spoken since then. Right?
    Odin's Rabid Dog Thanks this.
  9. Buckeye 60
    1,229
    1,269
    Apr 19, 2018
    just finish training with the trainer you have some trainer's let you go on your own and that's not all bad , you already figured out to go at your own pace . sounds like you are doing a pedal route . and that will give you a years worth of training compared to doing line haul training and you can switch to line haul after training if that's what you want .. I am not sure which ltl company you are with but any would be a lot better than any of the otr training companies. ... stick it out for a year then switch over if you wanted but could get a good job (you probably have one now and just don't know it )
  10. coastietruckin'
    269
    148
    Dec 28, 2015
    Southern NJ
    Thanks, Six. The 'incident' in the yard was moving a trailer. He said just hook up the blue line, dont worry bout the landing gear and put it to the side. We'll grab the one behind it. So, I did as told, hop back in cab, put her in gear, and now I'm trying to DRAG a pup trailer through the yard. Its a simple task, and lesson learned on my end to never cut corners, but dang it if I wudnt mad. This wasnt the only example, but just the last one that had me say time-out, I need to address whats going on here.
    I would say the 'struggling' is trying to balance the learning curve with having to adjust to the non-stop ltl world. So for instance, because I'm worried about the clock, and since my trainer is hanging out in dispatch not anywhere near me, I'll drop the ball on something having to do with the manifest, or not properly working the diade or something like that. I really am putting in an effort to learn as much as I can, but I feel at tines I'm trying to drink from a fire hose, and my trainer is sort of letting me just figure it out on my own. This is when I feel that my ability to operate safely is put in danger, and I do not want to harm anyone because I made a rookie mistake from feeling under the gun with no guidance.
    TripleSix Thanks this.
  11. coastietruckin'
    269
    148
    Dec 28, 2015
    Southern NJ
    Thanks, Buck. Appreciate it. I definitely know I have a career job ahead of me. Just gotta learn to run at my own pace until I get my feet under me.
