Rough first day as tanker.
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Ducktart, Apr 2, 2018.
  1. Ducktart
    Ducktart Light Load Member
    80
    84
    Jul 13, 2014
    Showed up the customer, checked in with security and pulled into the loading rack. Let the loaders know we were there and got back in the truck. Trainer fell asleep shortly after, I followed and got a good hour nap in. 2 hour drive to the customer, followed by another hour and a half nap while getting unloaded. 2 hour drive back to the yard and back at the house by 1630.
    Rough line of work, how do you guys do it.
  3. Smut
    Smut Light Load Member
    210
    275
    Jan 28, 2017
    Houston
    Is this at Martin Transport?
  4. ErieMcDreary
    ErieMcDreary Medium Load Member
    460
    393
    Dec 4, 2016
    Erie PA
    Hang in there driver. You will eventually have to work up a sweat.
    Luke628, Smut and Tanker312 Thank this.
  5. ncdriver1
    ncdriver1 Road Train Member
    1,106
    1,252
    Dec 3, 2012
    Just wait until you have to do a 120' pump offload of hazmat during summertime in the South.
  6. Tanker312
    Tanker312 Light Load Member
    82
    60
    Apr 16, 2017
    Wait till winter, when your internal valve is stuck frozen and you have to sit there with a blowtorch for 4 hours while in -5F weather.
    Or you have a 4 pot trailer, each requiring 40ft of hose, full chem suit, and check calls each time.
    Luke628 Thanks this.
  7. tucker
    tucker Road Train Member
    12,647
    40,423
    Jun 13, 2008
    IN
    What’s that load pay you?
    The rough part of the job may be not going broke.
    But then the driver you’re replacing probably made so much he retired
  8. AZ Pete
    AZ Pete Medium Load Member
    483
    853
    Dec 27, 2017
    :thumbleft:
  9. Luke628
    Luke628 Light Load Member
    276
    202
    Aug 20, 2013
    Houston,Tx
    Wow!
    Driver didn’t set brake, but the truck at first doesn’t move. Than when he starts putting the gas in the tank it lightens the weight of the truck causing the truck to roll and then a massive spill.
    I used to haul gas. We had a guy hook up and start dropping, and he broke the rule that you don’t leave the truck while loading or unloading.
    He went into the station to flirt with the female cashier and apparently hadn’t secured the drop gun as a customer came running in screaming where’s the driver, but it was too late. 1900 gallons on diesel on the pavement. The driver resigned immediately before they could fire him as he knew it was coming.
  10. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    Luke628. The guy that was training me a long time ago, did a similar trick. Only is was at an elementary school parking lot. Kids running through the fuel and then going back inside. Upset the teachers quite a bit . All the guy that was training me said " it's not that bad". Loaded up the hoses and away we went ! Never said a word to anyone. He did have a quite intense chat with the boss the next day though
