Rough Opti Idle Shutdown
Discussion in 'Freightliner Forum' started by Mroberts827, Oct 10, 2016.
  1. Mroberts827
    Mroberts827 Bobtail Member
    My cascadia with dd15 was using the Jake brake to shut down while using the opti idle so it was very smooth shutting down it has stopped using it now it's very rough to the point sleep is impossible. The dealer says all the parameters are correct it would be working but it's not they don't have a clue how to fix it. Anybody have any ideas?
  3. Dave_in_AZ
    423,845
    I have / had the same issue with the opti idle system. Starting up isn't an issue, but when it shuts down, it shuts down just like when you usually turn it off, and the last few rotations is just like someone shaking you to wake you up lol. Good luck.
  4. free spirited1
    free spirited1 Heavy Load Member
    981
    768
    Mar 18, 2012
    USA
    Go to a more reliable larger dealer shop??
  5. RoadRooster
    RoadRooster Road Train Member
    4,121
    6,710
    May 10, 2015
    Fort Myers, Florida
    Mine has never been soft even though it gets the rpms really low before turning off. I can't believe it is safe to wake a driver up two or 3 times per hour. I suspect the impact is worse than sleep apnea...someday a freightliner will have a fatal crash and the driver will claim he hasn't had a good nights sleep since he got the truck with opti idle.
    You heard it here first.
    free spirited1 Thanks this.
  6. free spirited1
    981
    768
    Mar 18, 2012
    USA
    Your onto something, my purse got a buzz in it.
  7. RoadRooster
    4,121
    6,710
    May 10, 2015
    Fort Myers, Florida
    LOL you left something turned on in there!
  8. free spirited1
    981
    768
    Mar 18, 2012
    USA
    Dang...what an imagination!!!! ...I'll check...lol
    RoadRooster Thanks this.
