Rough speed for each gear in a 13 speed.
Discussion in 'Questions From New Drivers' started by somers12, May 7, 2009.
  1. somers12
    somers12 Bobtail Member
    5
    Calgary, AB
    I've been driving a ten speed and know what gear I should be in at every mph. It seems that we are getting a 13 speed, and I was told it would be my truck. I do know the shifting pattern (learned here... Thanks) I assume the bottom six will be out of the way by 20 mph. Could you give me a rough Idea about the rest?
    Thanks... Steve
  3. kingsson
    kingsson Heavy Load Member
    757
    244
    Nov 29, 2008
    Omaha, NE
    I have a 13. You should never really need 1st unless you are going from a dead stop up a 6% grade with a full load... been there, done that. Yeah, bottom five are out of the way about 15mph. Split, then 6th goes to about 20, 7th to about 25 or so. 8th to 30, 9th 35... you get the picture. Listen to your engine and watch the rpm. If your ten speed has been a super 10, top will be really easy to learn.
    Baack Thanks this.
  4. somers12
    5
    Calgary, AB
    No, Not a super 10. So roughly, 10 is 40, 11 is 45, 12 is 50. I realize that individual trucks will be a little bit different, but at least I will have some idea.
    Thanks... Steve
  5. psanderson
    psanderson Road Train Member
    1,029
    402
    Oct 13, 2008
    Moline, Illinois
    You mean that you're wanting to shift by the speedometer instead of the tachometer?
  6. Red Fox
    Red Fox Road Train Member
    1,316
    432
    Jan 26, 2009
    Acworth, Ga.
    Gear rpm to ground speed will depend on your rears.
  7. TripleSix
    132,220
    Right.
    If you want specifics, find out what rpm that particular engine makes max torque numbers and shift there. Dont worry about the MPH, or in your case, KPH.
  8. SLCTrucker
    SLCTrucker Medium Load Member
    404
    199
    Jan 15, 2009
    Salt Lake City UT
    Forget the speed. Watch The Tach.
    1700 rpms is a good place for a upshift.
    1200 rpms is a good place to downshift.
    Depending on transmission, gearstep in low range will be about 450 to 500 rpms high range will be slightly less.
  9. sgreer78
    sgreer78 Light Load Member
    251
    62
    Jul 26, 2008
    St Louis, MO
    You shouldn't drive it any different than what you're used to. It's the same as a 9 speed but with the ability to split the top 4 gears. Not rocket science, just getting used to the new found flexibility.
  10. Red Fox
    1,316
    432
    Jan 26, 2009
    Acworth, Ga.
    Do you know what motor he is using?
    Right. Keep It Simple, Simon.
    FriedTater Thanks this.
  11. FriedTater
    FriedTater Keeper of The Snakes
    2,202
    887
    Mar 25, 2009
    United State of Texas
    Exactly . . . . . . .
