Rough speed for each gear in a 13 speed.
Discussion in 'Questions From New Drivers' started by somers12, May 7, 2009.
  1. AModelCat
    161,298
    I never gave a rat's behind about the speed in each gear. Never agreed with that method. Shift to keep the engine in the RPM band it likes and drive it.
  3. rch10007
    rch10007 Medium Load Member
    560
    860
    May 26, 2007
    Madison, AL
    Search the web for a gear ratio, rpm, etc... calculator. You can play with the number and see the correlation.
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    I know there's these things at the top left that show the date.
    But since we're here like the other guy said i really only split 7-8 positions if I'm heavy. Or just 8th if I'm light. Hardly ever split 5-6th
    70 is when I put it in the big hole
    Big Road Skateboard Thanks this.
  5. abyliks
    abyliks Road Train Member
    3,996
    9,394
    May 2, 2010
    ludlow MA
    A 4.56 rear will have different speeds then a 3.42 rear, depends on engine and where it likes to rev to as well. I usually only split 7 and 8th unless it’s something special situation
    And stay the #### out of the low hole on the high side
