routes to avoid?
Discussion in 'Questions From New Drivers' started by Skull_Leader, Dec 6, 2012.
  1. Skull_Leader
    Skull_Leader Light Load Member
    67
    18
    Oct 23, 2012
    Hey, I just started driving a month ago, and ran into some problems with routing. Basically I'm wondering if anyone has any insight on roads that are a pain in the butt to drive and should be avoided. I had this load going to martinsville, via and planned to route through some small roads south of the town. Turns out that there are mountains there that are a pita to get through. My trainer tells me to instead go north on 81 to Roanoke, then south on 220 which is way out of the way, but it, apparently avoid those mountains. He's not always going to be around to keep me from making those mistakes, and was wondering if there was a thread, or a list from experienced drivers of areas to stay away from. Like heavy traffic, or mountain roads, or space alien abduction zones. I did do a quick search and found nothing like that.
  3. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    experience is the only teacher
    a road i aviod another driver doesn't mind
    google maps and common sense helps too
    TRKRSHONEY Thanks this.
  4. 48Packard
    48Packard Ol' Two-stop Shag!
    8,348
    9,871
    Apr 19, 2009
    Could be anywhere
    I will say that 220 in southern VA IS a PITA, but I never avoid it. But if I had to drive it daily, I'd go nuts. I really dislike that road in that area. And, of course, 9 times out of 10 I've got 44000 pounds in the box....
  5. KE5WDP
    KE5WDP Road Train Member
    1,601
    1,050
    Mar 11, 2010
    Waskom, Texas
    One of my first trips in 2002, I thought I would be clever and take some back roads in PA. Hey if it's on the map, it should work right? Wrong. I was never so scared in my life. Texas rules don't apply to everywhere else.
    TRKRSHONEY and 48Packard Thank this.
  6. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    Maybe the simplest way to start is with a Rand McNally trucker's atlas, if the route is not highlighted in orange, you probably ought not be on it in a big rig. Yes I'm sure there may be exceptions, or if you have to make a delivery, but not for general routing.
    You don't want to run US 30 instead of the turnpike east of Breezewood in PA, nor do you want to take US 50 across WV instead of I-68 or the PA Pike, and in VA/WV you don't want to run US 250 or 33 unless you absolutely have to. On a simple map they all look like short cuts, and are fun on a nice motorcycle or Corvette, but not so much with an 18 wheeler.
    Skull_Leader and 48Packard Thank this.
  7. sherlock510
    sherlock510 Road Train Member
    1,066
    1,058
    Jul 26, 2011
    Intercontinental.
    I 70 through Colorado, in the winter time.
  8. TripleSix
    128,424
    PA routed me across that section of 30 with an oversized. 98000 lbs and they sent me up those steep grades.i thought for sure I would pop my motor.
    Made the mistake of trying to take a shortcut from Cedar City,UT to Flagstaff. Looked on the map and found US89A. On the map, it was a straight line. I should have known I was in trouble when the first hill, not even a mile from I15 was something like 11 or 12 percent grade. Glad I was empty.
  9. Homemade1959
    Homemade1959 Light Load Member
    130
    47
    Jan 21, 2012
    any of the 48 states
    Well follow the newbie rule from trucking school when it pertains to routing, until you get miles under your belt, big trucks run on big roads whenever possible. and just before i was to turn of that big road I would stop at TS like loves, pilot, etc. and ask more than one driver about the route I was going to take. and when you get money in your pocket buy that rand mcnally truckers GPS its with every penny.
  10. 900,000-tons-of-steel
    900,000-tons-of-steel Road Train Member
    1,511
    896
    Aug 17, 2012
    Florida
    Good advice. Gotta comment on some of those roads you mention. Route 30 is also an absolute nightmare when you get within an hour and a half east of Pittsburgh all the way through to the other side, stop and go, much traffic and narrow lanes (REAL narrow in some areas) but of course you probably already know this. Yea, 50 and 250 are pretty bad through WV for a big truck, not traffic-wise but mountain-wise. As far as 33, I've not had to take 33 west of the big road (79) but from there through Elkins isn't all that bad, and from what I remember it's four lanes in some parts. Going up over the pass near the state line into Va. can be an ordeal. There's those hairpin turns that claim a truck every few weeks or so when they're coming down heading westbound and one extremely nasty one in particular. Don't think I'd like to deal with that with the white stuff on the road but I think that road gets closed when there's an accumulation. That truck atlas is good advice.
  11. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    Chicago...
    Mikeeee
