Routing a new cosx in 579 Peterbilt daycab
Discussion in 'CB Radio Forum' started by Circle City Bandit, Apr 30, 2021.
  1. Circle City Bandit
    Circle City Bandit Bobtail Member
    I drive a 579 Peterbilt daycab. It has dual antennas and I want to run a single antenna . What do I have to do to access the fixed antenna mount to disconnect the co-phase coax and run a single coax? I can get part of the headliner loose but the rear side of it won't come loose. Any help would be appreciated. Thanks.
  3. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Why are you messing with it..Why not run the cophase..
  4. Lowboy456
    Lowboy456 Light Load Member
    278
    128
    Mar 14, 2017
    If the cophase is still working I'd try to save it in case you ever want to go back.
    If you can manage to fish some stiff wire through and tape your coax to it you might be able to pull the new coax through.
    I had to desolder the pl259 connector on the new coax to get mine pulled through in the Kenworth T800 without taking the entire head console out.
  5. Ozzy66
    Ozzy66 Bobtail Member
    6
    6
    Jun 13, 2021
    I drove a 2017 579 Sleeper. It had cab mounted antennas. I think the day cabs are mounted the same.. I don’t remember. However it isn’t just regular coax you can replace. The antenna mounts have a smaller female end like TV cable. Then the radio end is the normal coax male end for CB. If you decided to run new coax, you will have to have a similar end that is on the mount soldered on one end of the new coax. Also you can get an adapter if you don’t want to go that route. I don’t think it was ran cophased at all. The second antenna served as the AM/FM antenna. I may be wrong because I do not remember completely. I went ahead and just got better antennas and it worked great.
  6. Ozzy66
    6
    6
    Jun 13, 2021
    To access the antenna mount. Pop off the plastic cover for it on the outside. Should be couple of Allen screws under the cover.. mabye bolts? Then you can pull the mount off and see everything. It’s not hard at all.
