Routing
Discussion in 'Questions From New Drivers' started by davenjeip, Oct 16, 2010.
  1. davenjeip
    davenjeip Medium Load Member
    459
    257
    Dec 20, 2009
    Port Charlotte, Fl
    I know this has been covered before, but it is such a common term that it maxes out the search results before you get to any relevant topics. If there is a good topic on this subject, I suggest that we get it made a sticky.
    My routing sucks. Takes me forever and I often end up with less than stellar directions. I run enough stops and miles in a day that I can not afford to be driving in circles without running out of hours, and it has gotten to the point where the difference between a great day and a horrible one has much to do with how well I know where I am going.
    I'd appreciate it if someone could walk me through a good way to plan out a route, especially the local stuff because that's what's causing me the most trouble.
  3. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    Find the shortest route on your GPS, then match the directions to your road carrier atlas just to make sure there are no restricted routes or low bridges. This is the fastest and most reliable way I have found. After checking your RCA re-program your GPS to the correct route for big trucks and there you have it. I also write the directions on my side window with an erasable marker just in case my GPS messes up. You should be able to do multiple stops at once on your GPS. If not, then as soon as you arrive at one of your stops start planning your next drop. Good luck!
    mysticguido Thanks this.
  4. KDuBB
    KDuBB Bobtail Member
    44
    Oct 15, 2010
    Inverness,fl
    ^that is also what i do, and ive got a 6yr old GPS.. yeah most of the newer places it doesent have but alot of them it does, and even tho its not made for big trucks it still has an option for trucks that keeps you on mostly interstate and main highways...but the most important thing is CHECK IT with your road carriers atlas!!
  5. walstib
    walstib Darkstar
    Are there are dependable online sites that can help plot a route?
  6. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Les2 and walstib Thank this.
  7. walstib
    walstib Darkstar
  8. davenjeip
    459
    257
    Dec 20, 2009
    Port Charlotte, Fl
    Ok, so maybe it's not as much me as I thought.
    I first get directions from Mapsource on my laptop and compare them to GoogleMaps that I pull up off my phone, as using them together will often give me some additional information. Just got a Rand McNally GPS a couple weeks ago, so I gather up those directions too (this has improved things quite a bit). I compare that to my atlas, and get the main section of the route I need to run.
    From where I am at, it's usually pretty simple to get to a main highway. Either I am at one of the few spots I usually pick up a load, so I already know my way out, or if I am somewhere else I can either follow the same route I used to get in and/or I can ask directions at the dock.
    Highways and the main routes are easy.
    What is killing me are the local directions, getting from the highway to the shipper/receiver.
    I use the same stuff that I use for the highways, but I can also pull up directions from the Qualcomm and I commonly call up the receiver for directions. Seems that none of these are ever right. You'd think that with us being a dedicated account that the Qualcomm would be right, but it very often isn't. Then the person answering the phone at the company seems to rarely know correct directions as to how to get to their building, which wouldn't be so bad if they would just say that instead of giving me something incorrect.
    I find the place on the first try maybe 3 out of 5 times, but the other two involve me driving in circles, turning around in parking lots, and asking for directions. Might not be a big deal on a typical OTR job, but it's common for me to run 500+ miles in a day with 3-6 stops. This burns up a lot of my time and I've gone over my hours twice in the past month.
    Guess I'm doing allright and it's just the nature of the business?
  9. notarps4me
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Your welcome!
  10. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    The local stuff is where it gets tricky. Many towns have truck specific routing. It's best to call the customer and they will tell you the best way in. Automated directions are better. After awhile you learn most of it. Of course we always go to new places but you will repeat alot too.
    Google Maps is good in a way as you can get a satellite visual and see what neighborhoods and industrial areas you are dealing with. Then compare it with your GPS. I always use legs if the GPS is wrong. If you need to go one more exit or such, detour to it and then it's fixed. US and state routes are a no brainer. It's the other roads you have to watch. If you have shortest route and fastest route options on your GPS, I learned the fastest route is more reliable and quicker.
    Qualcomm and Peoplenet are not dependable because they are made mostly from drivers that are surprised they found the place. So they tell dispatch, not knowing there is a better way.
  11. KDuBB
    44
    Oct 15, 2010
    Inverness,fl
    running dedicated your FM should be able to PINPOINT ur butt right in there from a main highway as he or she should be giving these directions out ALLL the time...but alas i guess not everyone is so willing to help us out..
