RPM on 3406 B cat
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Largecar359, Oct 27, 2012.
  1. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    Hey I have a 3406b cat. And the motor seems to want to cruise at 1350-1500 rpm. Traditionally these motors are suppose to be wound up a little higher at least the others I have owned. I recently put a brand new (non reman) 13 speed trans. It is paired with 3.55 rears on high rubber. 1500 rpm puts me at 74 mph. 1350 puts me at 65mph and the motor and truck feel comfortable there. Good oil pressure and motor sounds smooth. Some have told me that rpm will wash out a bearing on these motors. I would agree if the motor wasn't running as smooth as it is. Will that rpm do damage or am I ok at these numbers?
    My last 3406 b liked to run at 1625. This one doesn't feel the same that high up. It's runs more like my other truck c-15 cat.
    Any input will help.
  3. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    I've never heard that and as long as you are getting good fuel mileage at that RPM I'd keep doing it. Just keep an eye on your pyro.
    Tb0n3 Thanks this.
  4. YETI1
    YETI1 Light Load Member
    182
    40
    Jan 1, 2008
    kansas
    Silly question are you sure your speed is right?
  5. flc120
    flc120 Heavy Load Member
    916
    122
    Jul 11, 2012
    Miami,FL (yeah i know :( )
    seems as if your set up is just what i want to lower rpms and get some better highway fuel economy.
    i run about 65-67mph at 1600 rpm or so but i have a b-model cat, 15spd o/d and 3.90 rears.... would love to get a 1500rpm at 70 mph setup going, but since i ve been running these TIN CANS locally they all have insta pop recaps on them which limit me to 55-60mph on loaded runs.
    you have a nice setup there what truck is it in?
  6. snowblind
    snowblind Heavy Load Member
    775
    636
    Jan 29, 2011
    conover nc
    you can run that or any other diesel at 2100 all day some a little higher
  7. flc120
    916
    122
    Jul 11, 2012
    yes you can as above poster lsted but the question is how long will your diesel last being run at 2100 constantly... especially highway speeds for long periods of time.
  8. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Power, industrial units operate on the govenor all day long...:biggrin_25514:
    Buckshot7cz Thanks this.
  9. Largecar359
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    I set the truck up to run lower rpm at highway speed. My pyro is good. And yes my speeds are calculated correctly I specifically set the truck up to run 80-85 mph at 1700 rpm. At at 65-70 mph at 1350-1450 rpm is my optimal fuel mpg. 6.5. Which is good for a 1985 pete with a manual motor. And I seem to get that loaded or empty.
    Thanks for everyones input seems like I'm good to go.
  10. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Wear is based on fuel consumed.
    You could run 1200 at full boost and have more wear per mile than running at 2100 at 5 lbs boost.
    I like to grab the gear that will let me git along at my chosen speed using the least boost.
  11. Largecar359
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    Which is my other point my boost is fine at 1350-1500 and my torque curve is on the middle to lower half. Which pulls fine from 1300. I really don't think I need to run it higher. I just wanted to see what you guys thought. This 3406 b. Just runs a lil different from my others.
