RPM stays at 1700 cruising@ 65
Discussion in 'Experienced Truckers' Advice' started by Harman514, Nov 28, 2019.
  1. Harman514
    Harman514 Bobtail Member
    Nov 28, 2019
    I have cascadia Cummins isx 500
    Rpm stays at 1700 cruise @65
    Tire size 11r 22.5
    Is there i can do to lower the rpms ?
    Bakerman Thanks this.
  3. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,521
    May 28, 2015
    New rear ends.
    Lepton1 and Bean Jr. Thank this.
  4. jammer910Z
    2,446
    6,521
    May 28, 2015
    That's what... 390s ?
  5. misterG
    misterG Road Train Member
    2,884
    8,981
    Jan 21, 2009
    ask my dispatcher
    shift again.
    magoo68, PE_T, AModelCat and 8 others Thank this.
  6. MACK E-6
    48,340
    221,483
    That might be what I would try first. :biggrin_25523:
    Cattleman84, LoneRanger, PE_T and 7 others Thank this.
  7. jammer910Z
    2,446
    6,521
    May 28, 2015
    Yeah.. there might be a couple more gears they haven't discovered yet.
    OP.. what tranny is in it ?
    If it's an 18, you gotta flip and lift.
    You'll find some more.
    Cattleman84, LoneRanger, PE_T and 3 others Thank this.
  8. misterG
    2,884
    8,981
    Jan 21, 2009
    ask my dispatcher
    To be somewhat fair. Our straight trucks do run high rpm's at speed.
    But they're all 6 speed transmissions.
    My little S\A Cascadia with a dd13, and 10 spd Eaton only get 1450 rpm at 65 mph.
    PE_T, D.Tibbitt and FlaSwampRat Thank this.
  9. MACK E-6
    48,340
    221,483
    ...And smaller engines too, I’m sure. They usually tach quite a bit higher.
    My Pete lugs along at 1100 running 65. I won’t run 12th gear on anything but interstate. Anywhere with a 55 mph posted I lock it in 11th.
    Of course, on our newest trucks now you’re limited to 53 mph in 11th gear. :rolleyes:
    Trucker61016, PE_T, x1Heavy and 2 others Thank this.
  10. misterG
    2,884
    8,981
    Jan 21, 2009
    ask my dispatcher
    Yup, smallest engines the Boss can find. For our straight turcks.
    We have a S\A Columbia geared like your Pete in a 10 spd. We never use 10th anywhere, but on the interstate.
    Other wise it lugs and belches black smoke.
    D.Tibbitt Thanks this.
  11. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Slow it down you speed demon!
    whoopNride, FlaSwampRat and D.Tibbitt Thank this.
