Rpms causing shifting too early....2012 Cascadia
Discussion in 'Ask An Owner Operator' started by trucky909, Mar 29, 2020.
  1. trucky909
    trucky909 Light Load Member
    130
    33
    Jul 4, 2014
    ***This is a manual transmission.....not automatic...***
    I've posted before and can't figure this out. I have a deleted 2012 Cascadia dd15 manual transmission.
    The rpms are telling to shift 10 mph before I have to. Before.....I'm in 7th at 25mph....8th at 35mph and s fourth.
    Now....im in 7th at 15 to 18mph at 1500 rpm.....im in 8th at 25mph at 1500 rpm.
    What's the issue here? I had a new cluth put in 7 months ago, and this issue has been going on for almost a year.
    I had mechanic check and adjust ECM and made adjustments about 2 weeks ago. Still didn't fix issue.....
    What do you think the issue is with this....can it be a transmission issue or something? Was the clutch put in wrong?
    Thanks
  3. Numb
    Numb Crusty Curmudgeon
    4,123
    9,562
    Jan 30, 2012
    Charlotte, N.Carolina
    the engine doesn't figure out how you want to shift, you figure out how it needs to be shifted.
    Bean Jr. Thanks this.
  4. trucky909
    130
    33
    Jul 4, 2014
    Give me something better than that. You're basically telling me to adjust to this issue. I can't adjust to my truck being in 8th gear at 20-25mph @1500 rpms.
    I need to know why is it like this now, because it wasn't before.
  5. Snow Hater
    Snow Hater Medium Load Member
    480
    980
    Dec 26, 2019
    What is telling you to shift? The driving I've done with a 10 speed didn't have any indicator other than the tach and speedometer. The truck was a 2016 Freightliner.
    I just re-read your post and your description looks like you have an auto shifter not a manual. Need a bit more clarification please.
    Bean Jr. and okiedokie Thank this.
  6. okiedokie
    okiedokie Road Train Member
    12,620
    95,521
    Jun 13, 2011
    PNWET
    20-25 mph in 8th doesn't sound right.
  7. olddog_newtricks
    olddog_newtricks Medium Load Member
    639
    2,162
    Jun 3, 2018
    Do you have one of those progressive shift programs in your software that needs to be turned off?
    blairandgretchen Thanks this.
  8. mud23609
    mud23609 Medium Load Member
    652
    1,444
    Mar 9, 2015
    That year range of cascadia is known for the clusters going bad. Usually it’s the Speedo that ends up being off but sometimes it’s the tach. Bet your fuel gauge is probably wonky too. That’s usually the first thing that starts failing. The fix is to replace the cluster.
    Bean Jr., magoo68 and flood Thank this.
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    Your Engine decides when to shift. A properly matched automatic will know when it's time to shift off the current engine situation.
    There are two RPM numbers to shift at up or down. Thats it. Nothing complicated. Road speed means nothing.
    You are not doing 25 at 8th gear. It wont work. Thus instruments are false. Have a shop look at them closely.
  10. AModelCat
    160,335
    So don't move the stick to the next gear until the RPM comes up to where it needs to be.
    What's the issue with that. Your hand moves the gearshift, your feet run the clutch and throttle.
    Dave1837 Thanks this.
  11. Ivansoto0123
    Ivansoto0123 Bobtail Member
    9
    Sep 15, 2016
    What speed are you doing in 9th and 10th?
