RTLO 18913A questions
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckerbangin, Mar 16, 2016.
  1. truckerbangin
    truckerbangin Light Load Member
    262
    44
    Jan 22, 2013
    is this a overdrive or double overdrive box. what are the pro's and con's of this 13spd over the fro 15210c that i'm currently running.
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    It's a double overdrive.
    There's no cons , all pros over your 10 speed
    Bean Jr. and truckerbangin Thank this.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Yes, the O in the part # means overdrive. Technically it is a single overdrive, which is 8th gear. In reality, since you can split the high range, you have 2 overdrive ratios, 8th low (0.86) and 8th high (0.73).
    truckerbangin Thanks this.
  5. Ozdriver
    Ozdriver Heavy Load Member
    767
    1,390
    Oct 16, 2015
    Australia
    Doesn't the "9" part of it mean double overdrive? I know the O means overdrive as well
  6. Ozdriver
    767
    1,390
    Oct 16, 2015
    Australia
    Being double overdrive instead of single overdrive he'd need lower ratio diffs or the truck would be too fast, that's my take on it anyway
  7. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    I never really paid much attention to the 9, but since you asked I looked in the book and that is the design level.
  8. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    9 is the build level, a 16713 would have the same ratios.
    The 15210C should have a .74 overdrive, the change to .73 will not require a rear end ratio change.
  9. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    18918 has the fine spline output.
    The 18718 or any 7 for that matter are course spline output.
    The 9 series came out because guys were having problems with the yolks coming loose.
    Apparently the fine spline don't wear like the course 7 series.
    I do know that to get a yolk off a 9 series that's been on a long time, sometimes have to be cut off with a torch.
  10. Ozdriver
    767
    1,390
    Oct 16, 2015
    Australia
    Tbh, I don't know anything about the 10 speeds, but when I wanted to change my Spicer for a Roadranger, I was told you couldn't get a single overdrive in anything above the 1600 ft/lb series. As I wanted 2200 ft/lb (RTLO 22918B) I had to settle for double overdrive and re-ratio the diffs, which wasn't a bad thing as it happens because now I've got a super-low Lo gear. (4.56 diff ratio). Perfect trans combination for my line of work.
