Rtoo14613 Shift pattern
Discussion in 'Trucks [ Eighteen Wheelers ]' started by J m J, Jan 24, 2017.
  1. J m J
    J m J Bobtail Member
    13
    Can the shift pattern be changed By putting on a different shift tower . Or do the gears on the countershafts have to be changed?
  3. Lonesome
    Lonesome Mr. Sarcasm
    11,475
    23,725
    Dec 15, 2007
    Northern Indiana
  4. noluck
    noluck Road Train Member
    1,616
    11,683
    Jun 10, 2011
    greenville,sc
    Gotta swap gears
  5. wore out
    wore out Numbered Classic
    16,700
    204,125
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Put an rtx top on it and your good to go
    snowman_w900 and BoxCarKidd Thank this.
  6. noluck
    1,616
    11,683
    Jun 10, 2011
    greenville,sc
    Hmmm, learn something new today. Thanks
  7. J m J
    13
    I sent this truck to votech I was told gears had to be changed. But the School said it may be able to be done with a shift tower . So I just wanted to see if someone had done it That way . Thanks Mike
  8. wore out
    16,700
    204,125
    Jun 5, 2013
    If you change gears you change ratios. An rto has overdrive forward. An rtx has overdrive to the rear. The x top has an extra rail to reverse them. I have done it and seen it done countless times
    snowman_w900 and Ozdriver Thank this.
  9. Ozdriver
    Ozdriver Heavy Load Member
    767
    1,390
    Oct 16, 2015
    Australia
    Why would you do this or is it to avoid confusion. I remember the old 15 overs used to have overdrive forward but everyone got used to them.
    BoxCarKidd and noluck Thank this.
  10. wore out
    16,700
    204,125
    Jun 5, 2013
    Yes to avoid confusion. Some can't get used to the horse shoe pattern after driving an H pattern for so long. And vise versa of course
  11. J m J
    13
    I farm and have 6 trucks and 5 drivers so they switch trucks often and if they don't shift the same The drivers sometimes complain. I don't mind it myself.
