Run overhead or not?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by noguns3, May 2, 2013.
  1. noguns3
    noguns3 Light Load Member
    52
    13
    Jan 7, 2007
    Minnetonka, MN
    Detroit S60 pre-EGR. Haven't ran overhead in over 250k miles. Truck runs good, 6.7 mpg avg. Some say run overhead every 150-200k. Some say if it isn't broke, don't fix it. What say the old timers? The Detroit shop foreman told me he would leave it alone, but my decision. I tend to lean toward not touching it. He says sometimes after a tuneup the truck runs worse and actually loses fuel mileage.
    I also have a friend who runs 15 trucks. He says he changes turbo after 500k no matter what. He claims it runs better and lowers his chances of blowing turbo on the road. I guess you can blow a turbo at anytime, so what does it matter? You can blow a brand new turbo. Thanks for any feedback.
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    Turbo at 500k is about at the end of its service life. So i can't fault him there. Especially if his history shows 500-600k he's replacing turbos. There are indicators to turbo failure though that should give yoi adequate warning though.
    Overhead wouldn't be a bad idea. This engine closes the valve clearance as it wears. So the gap goes away. I'd be leaning towards doing it.
  4. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Just pop the rocker cover off and inspect the cam and followers,just check the lash on all valves and see if there in spec if they are leave them alone if not adjust them.
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    Detroit intake valves tend to tighten up. We do VA's initally at 75,000, then 300,000 after that. At 300,000, most of the intake valves are down to 0.002-0.003" lash. Run them too tight and you chance burning a valve. Most of our VA's end up being just a check on the the injectors and exhaust valves, we rarely have to adjust those, but the intakes are always too tight. The initial one at 75,000 is by far the worse, it all over the place (some tight some loose). Once we set the initial, things settle in and lash stays fairly consistenst (all wear about the same).
    My opinion is to run through the overhead, don't touch anything that is in spec, adjust what is out. Check the rocker rollers closely too. Ceramic rollers are very tough, but once they start pitting, they go out fast and take the cam with it.
  6. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Yes, Detroit valves do like to tighten up. I would run the overhead. 200K is too soon, but you are about right on now. Turbo should just be inspected for radial and axial play. I think 500K is too soon for a PM replacement.
