Run the truck all night in negative temps or plug it in?
Discussion in 'Ask An Owner Operator' started by Dadetrucking305, Dec 24, 2022.
  1. Dadetrucking305
    Dadetrucking305 Heavy Load Member
    984
    2,583
    Sep 15, 2011
    Cibolo,Texas
    Wondering if I should run my truck all night in negative temps or just plug it in and deal with the cold leaks and such? And if I should idle at what rpm is ideal?
    singlescrewshaker Thanks this.
  3. Diesel Dave
    8,875
    26,148
    Jan 20, 2010
    Hesperia, Ca.
    If you keep the engine on, make sure you kick up the idle.
  4. Siinman
    Siinman Road Train Member
    5,360
    13,653
    Mar 5, 2017
    Kansas City, MO.
    Plug it in if you can. Not sure what you mean by the cold leaks?
    Rideandrepair Thanks this.
  5. Tb0n3
    Tb0n3 Road Train Member
    4,652
    9,357
    Oct 5, 2012
    Earth
    Not a whole lot of benefit unless you haven't treated your fuel. You'll get extra wear from cold starting but not as much as running it for 10 hours at idle. Really depends on how cold you're expecting.
  6. austinmike
    111,398
    I'd let it run. Kick the idle up.
  7. Midwest Trucker
    5,911
    21,379
    Aug 31, 2018
  8. skallagrime
    skallagrime Road Train Member
    3,856
    9,943
    Apr 10, 2012
    Indiana
    And how long
  9. Long FLD
    Long FLD Road Train Member
    12,113
    50,024
    Mar 4, 2015
    Depends on how confident you are in your fuel. Plugging the block heater in won’t do much to help if your fuel is bad and your filters plug up.
  10. Rideandrepair
    17,367
    56,351
    Aug 8, 2015
    I’d shut it off, plug it in. Any cold leaks, lets you know if a clamps loose. Shouldn’t get any if you have constant tension type clamps. Unless it’s a brand new Truck. Silicone hoses only. Any other cold leaks are a problem.
    Magoo1968, JoeyJunk, loudtom and 4 others Thank this.
  11. 77fib77
    77fib77 Road Train Member
    10,914
    69,652
    Jul 7, 2010
    St Louis
    Treat the fuel. Run for a bit and plug it in. .????
    silverspur and JoeyJunk Thank this.
