Running an empty trailer with the front axle chained up
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Farmall5C, Apr 15, 2019.
  1. Farmall5C
    Farmall5C Bobtail Member
    Apr 15, 2019
    I’m about to do a 2000 mile trip with an empty trailer. Dexter axle is 14,000 pound capacity. Slippery Springs. Can I takeoff the front two tires or chain the front axle up so those tires pretty much stay off the ground? Will it impact or cause ab normal wear on the suspension? Has anyone done this? Your thoughts?
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    WHY?
    You need all the braking you can get. Otherwise your trailer becomes a bully shoving YOU off the road.
    Tow the thing like you always have. Leave that trailer alone to run on the pavement just like it's designed to do empty or loaded.
    201 Thanks this.
  4. Farmall5C
    Apr 15, 2019
    Trailer weighs 5000 pounds. Tires are 17 1/2 inch rated of 4000 each. Two tires on the road bs four tires causing jerking as you keep going through the bumps. Many 40 foot Hot shot trailers now have airlift front exes. So my point is the question again. Will it be causing issues if I raise the front axle?
    tnpete Thanks this.
  5. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I would do like you said, remove the front tires and chain up the axle and roll.
  6. Farmall5C
    Apr 15, 2019
    Sorry for the grammar. Voice text.
    x1Heavy and Bean Jr. Thank this.
  7. 201
    201 Road Train Member
    12,288
    25,105
    Apr 16, 2014
    high plains colorado
    Why are you taking the tires off? What are "slippery springs"? I tell ya', sounds like a big hassle. I agree with x1, just run it.
    x1Heavy Thanks this.
  8. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    I brought a stolen trailer back from Philly once. It was a brand new Fontaine 45-75' stretch with 4 baldies, 1 with a railroad spike in it. There was a tire shop a little ways from where I picked it up(I believe they were the thieves, no proof), they removed the tire with the spike in it and I chained the axle. Brought it back with 3 baldies. That's how we rolled back in the 80's. Passed a couple of staties on I-195E, they never gave me a second glance.
    201 and x1Heavy Thank this.
  9. x1Heavy
    34,017
    42,135
    Mar 5, 2016
    I appreciate that. I was beginning to wonder.
    That voice text is interesting. No more typing.
    I'll partially meet you on the original question, PROVIDED your trailer has a properly installed airlift device for a axle.
    Otherwise I'd just run it. There have been occasionally a trailer or a dump truck that has a suspension built so that when it's empty one of the two axles are coming up and stay up. Those are not the trailers I worry about here.
    If you have a trailer that you feel the need to chain up a axle or otherwise force it to come up into the air above the pavement, that seems like a awful lot of work for little gain.
    I don't have anything else to offer, it would just be a broken record on my end repeating.
  10. Steamnsteel
    Steamnsteel Bobtail Member
    39
    30
    Jan 19, 2016
    A friend of mine was put out of service by the DOT for pulling with one axle chained as described by the original post. Run it as designed, you may need the braking power of both axles.
  11. ZVar
    ZVar Road Train Member
    10,911
    23,827
    Sep 10, 2010
    Flint, MI
    I see nothing wrong with it. Heck, my last job we had 53' vans that did this automatically via air. When it weighed over x pounds it would drop the second axle, otherwise the axle would be lifted.
