Running COAX in Mirror mount for Pete 386
Discussion in 'CB Radio Forum' started by Eaton18, Dec 26, 2011.
  1. Eaton18
    Eaton18 Road Train Member
    1,755
    1,104
    Sep 3, 2011
    Waverly, KS
    I have a Wilson 2000 trucker mounted on my right mirror. Right now the coax is ran through the door. So far no problem, as I don't open the right door much. I did look at trying to get the coax through the mirror bracket hole, but due to time, had to leave it alone. It seems that I would need to take half the dash out to run the coax.
    So is there anyone with some experience in this, that can provide me with some insight? Once I find out what it takes, I'll pick up a second antenna, for the left side, and a co-phase coax and run them properly.
    My radio is mounted to the underside of the upper cubby hole, the plate that's provided by the factory. So I would need to run the coax up the pillar then over.
    Is it easier to run/chase the coax from the radio to the mirror, or vice-versa?
  3. Rat
    Rat Road Train Member
    You are going to have to take the over head apart as the coax is strapped to the body in a few places. Once you get it that un done then it shoudl be free to pull either way. Tape some weedeater line to the coax and pull it through. If that is your truck in the picture then I would not worry about cophasing, You will be much better off staying single.
  4. Eaton18
    1,755
    1,104
    Sep 3, 2011
    Waverly, KS
    Yep, that's my truck, and I'll leave it single. Wasn't sure if I would gain much by going co-phase, but reading a lot of your posts, you do seem to know what you're talking about. Would I be just a little better off, putting the antenna on the left mirror? Or would it not make enough difference to mess with?
    Now you say the coax is strapped to the body in a few places? I ran my own coax, and it just goes through the door opening. Are you talking about any existing coax? There is an old, cheapo co-phase that runs through the mirror brackets.
    Overhead, as in the overhead that has the cubby holes? I'll take a good look at it this next week. I hope it's easier than getting the door pillar off,which looks like I have to take the glovebox, ie; dash out.
    Thanks Rat.
  5. highside
    highside Medium Load Member
    441
    510
    Feb 6, 2010
    Kansas
    What year is your 386? If it's an 06 or newer, the a pillar trim cover just pops off after you take the 2 screws out of the grab handle. Just pull the weather stripping back and the plastic trim above the door off and you'll see how it pulls off. I can't say for sure on an ultra cab, but the coax in a flat top lies loose above the header. It's not attached anywhere.
  6. Eaton18
    1,755
    1,104
    Sep 3, 2011
    Waverly, KS
    Mine is an '08. Just got back home, and after being in the darn thing for the last few days and nights, I never looked at it. I think the main reason was, I was told that I would probably be getting a new KW T800 in February. He has some new ones ordered, and is getting rid of the '07 & '08 Pete 386s. We've been having nothing but problems with the REGEN. The KWs will have the PACCAR engines, and will have that DEF stuff. Boss thinks they will be better.
    So if I'm going to get another truck soon, I'll just leave it as is for now.
  7. mike5511
    mike5511 Road Train Member
    3,155
    1,546
    May 15, 2011
    NW Arkansas
    Through trial and error I have come to believe you need to wind the suckers out fairly often to keep the need for REGEN down. FWIW
  8. Eaton18
    1,755
    1,104
    Sep 3, 2011
    Waverly, KS
    They do get wound out, 65-72mph. What's seem to help so far, is changing the fuel filters more often. They were waiting to change them at oil changes, 20k miles, but now are changing them every 10k. Still we have at least 1 truck a week go down due to the REGEN.
  9. mike5511
    3,155
    1,546
    May 15, 2011
    NW Arkansas
    I slip seat, but I've never had to Re-gen, and we've had them since 09. My brother has his own truck, and he has never had to re-gen either. When you are pulling a hill, you need to down shift early and keep the RPMs up in the 1800 + range every now and then. Seems to be the key.
    P.S. I have no scientific evidence to back this up......:biggrin_25526:
  10. Eaton18
    1,755
    1,104
    Sep 3, 2011
    Waverly, KS
    Maybe that's why I've yet to have a problem. When I get behind a slow car (or truck), I'll drop down/split a gear, and run for miles that way, instead of running in 13 high, at about 12-1300.
    Most of the time pulling a hill, I'll let her back down to about 1200 then catch a lower gear and run it up till she just hits the peak for that gear, which can be a half mile or more.
  11. mike5511
    3,155
    1,546
    May 15, 2011
    NW Arkansas
    I agree, I think lugging them around stops everything up. It makes sense to me.
