Running Empty out of Columbus OH Market, How is every one else doing
Discussion in 'Ask An Owner Operator' started by atrucker, May 14, 2014.
  1. atrucker
    atrucker Light Load Member
    227
    25
    Sep 21, 2012
    This is my 2nd week here in Columbus OH market trying to book a lousy lousy load to northeast. All the calls made for booking the load were answered by some kind of retarded under cover gang by saying either the load has been covered or the rate is too too low which is unaffordable.
    How is every one else doing ???
  3. Pound Puppy
    Pound Puppy Heavy Load Member
    974
    868
    May 31, 2010
    Amherst, OH
    Look to other Ohio areas, low too mid 2's depending where
    GITRDUN45 Thanks this.
  4. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    I'm going to guess that your from the north east. Because if you think its bad in OH the north east is just as bad if not worse
  5. wonderdog24
    wonderdog24 Medium Load Member
    377
    127
    Mar 1, 2012
    Puyallup,Wa
    Why would you go to that area with Load Density in the negative?????? Failing to plan is planning to fail.... Hope you figure it out soon....
    Mid-Western States
    [TABLE="class: density_table"]
    [TR]
    [TD="class: header_density_blank"] [/TD]
    [TD="class: header_density_direction, colspan: 4"]Number of Loads Picking Up[/TD]
    [TD="class: header_density_direction, colspan: 4"]Number of Loads Dropping Off[/TD]
    [/TR]
    [TR]
    [TD="class: header_density_state"]State[/TD]
    [TD="class: header_density_trailertype"]Flatbed[/TD]
    [TD="class: header_density_trailertype"]Van[/TD]
    [TD="class: header_density_trailertype"]Reefer[/TD]
    [TD="class: header_density_trailertype"]Specialized[/TD]
    [/TR]
    [TR]
    [TD="class: header_density_data"]IA[/TD]
    [TD="class: header_density_data"]1694[/TD]
    [TD="class: header_density_data"]955[/TD]
    [TD="class: header_density_data"]517[/TD]
    [TD="class: header_density_data"]109[/TD]
    [TD="class: header_density_data"]3209[/TD]
    [TD="class: header_density_data"]1298[/TD]
    [TD="class: header_density_data"]620[/TD]
    [TD="class: header_density_data"]91[/TD]
    [/TR]
    [TR]
    [TD="class: header_density_data"]IL[/TD]
    [TD="class: header_density_data"]6387[/TD]
    [TD="class: header_density_data"]2567[/TD]
    [TD="class: header_density_data"]1213[/TD]
    [TD="class: header_density_data"]244[/TD]
    [TD="class: header_density_data"]6735[/TD]
    [TD="class: header_density_data"]3496[/TD]
    [TD="class: header_density_data"]1580[/TD]
    [TD="class: header_density_data"]222[/TD]
    [/TR]
    [TR]
    [TD="class: header_density_data"]IN[/TD]
    [TD="class: header_density_data"]6529[/TD]
    [TD="class: header_density_data"]2021[/TD]
    [TD="class: header_density_data"]432[/TD]
    [TD="class: header_density_data"]1491[/TD]
    [TD="class: header_density_data"]6641[/TD]
    [TD="class: header_density_data"]2480[/TD]
    [TD="class: header_density_data"]954[/TD]
    [TD="class: header_density_data"]108[/TD]
    [/TR]
    [TR]
    [TD="class: header_density_data"]KY[/TD]
    [TD="class: header_density_data"]3304[/TD]
    [TD="class: header_density_data"]1042[/TD]
    [TD="class: header_density_data"]448[/TD]
    [TD="class: header_density_data"]80[/TD]
    [TD="class: header_density_data"]3474[/TD]
    [TD="class: header_density_data"]1125[/TD]
    [TD="class: header_density_data"]492[/TD]
    [TD="class: header_density_data"]81[/TD]
    [/TR]
    [TR]
    [TD="class: header_density_data"]MI[/TD]
    [TD="class: header_density_data"]2773[/TD]
    [TD="class: header_density_data"]1059[/TD]
    [TD="class: header_density_data"]522[/TD]
    [TD="class: header_density_data"]130[/TD]
    [TD="class: header_density_data"]4380[/TD]
    [TD="class: header_density_data"]2180[/TD]
    [TD="class: header_density_data"]1195[/TD]
    [TD="class: header_density_data"]235[/TD]
    [/TR]
    [TR]
    [TD="class: header_density_data"]MN[/TD]
    [TD="class: header_density_data"]1245[/TD]
    [TD="class: header_density_data"]578[/TD]
    [TD="class: header_density_data"]343[/TD]
    [TD="class: header_density_data"]66[/TD]
    [TD="class: header_density_data"]3943[/TD]
    [TD="class: header_density_data"]1886[/TD]
    [TD="class: header_density_data"]957[/TD]
    [TD="class: header_density_data"]157[/TD]
    [/TR]
    [TR]
    [TD="class: header_density_data"]MO
    [/TD]
    [TD="class: header_density_data"]3368[/TD]
    [TD="class: header_density_data"]1883[/TD]
    [TD="class: header_density_data"]1226[/TD]
    [TD="class: header_density_data"]215[/TD]
    [TD="class: header_density_data"]4874[/TD]
    [TD="class: header_density_data"]1896[/TD]
    [TD="class: header_density_data"]997[/TD]
    [TD="class: header_density_data"]95[/TD]
    [/TR]
    [TR]
    [TD="class: header_density_data"]OH[/TD]
    [TD="class: header_density_data"]5845[/TD]
    [TD="class: header_density_data"]2202[/TD]
    [TD="class: header_density_data"]802[/TD]
    [TD="class: header_density_data"]242[/TD]
    [TD="class: header_density_data"]8455[/TD]
    [TD="class: header_density_data"]3292[/TD]
    [TD="class: header_density_data"]1729[/TD]
    [TD="class: header_density_data"]277[/TD]
    [/TR]
    [TR]
    [TD="class: header_density_data"]WI[/TD]
    [TD="class: header_density_data"]2475[/TD]
    [TD="class: header_density_data"]1778[/TD]
    [TD="class: header_density_data"]822[/TD]
    [TD="class: header_density_data"]3903[/TD]
    [TD="class: header_density_data"]1388[/TD]
    [TD="class: header_density_data"]1074[/TD]
    [TD="class: header_density_data"]173[/TD]
    [/TR]
    [TR]
    [TD="class: header_density_data"]WV[/TD]
    [TD="class: header_density_data"]1443[/TD]
    [TD="class: header_density_data"]296[/TD]
    [TD="class: header_density_data"]65[/TD]
    [TD="class: header_density_data"]23[/TD]
    [TD="class: header_density_data"]1537[/TD]
    [TD="class: header_density_data"]70[/TD]
    [TD="class: header_density_data"]33[/TD]
    [/TR]
    [/TABLE]
  6. whoopNride
    whoopNride Road Train Member
    1,649
    5,015
    Jan 13, 2008
    Miss.
    The load density for vans is negative in most states on your chart. What do you suggest doing ?? avoiding the Midwest all together ??
    Just curious
  7. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    Suggestion? Buy a reefer ... or if flat is your thing, go that route ... Hell, even I had someone call me today, asking if I had a flat in Arkansas ?? I don't even run flatbeds. Much less the southern part of the country ...
  8. RAGIN CAJUN
    RAGIN CAJUN Light Load Member
    198
    116
    Jun 20, 2013
    Hey...just curious where did find this de with table?
  9. wonderdog24
    377
    127
    Mar 1, 2012
    Puyallup,Wa
    This is on the internet truckstop.... Sign in-on the right will be a tab= MY TRUCKSTOP-CLICK ON IT..... NOW on the left of the screen will be a decision tools tab.... Scroll over it..... Load densities is what it is called..... Click on it... map will come up with the different regions click on one n it will show you everything That I posted
  10. Rich_Trucking
    Rich_Trucking Light Load Member
    248
    21
    Dec 11, 2012
    How often is the load densities updated on ITS?
  11. wonderdog24
    377
    127
    Mar 1, 2012
    Puyallup,Wa
    I would imagine it's updated every minute or 2.... Its just simply a compilation of all the postings.... For that specific region
