Running out of hrs at shippers-doesnt seem to be any solution
Discussion in 'Questions From New Drivers' started by chp56, Jan 28, 2013.
  1. chp56
    chp56 Light Load Member
    150
    33
    Sep 25, 2011
    Barstow, Ca
    Company skirts the issue or tells me "Remove fuse and tell them you've broken down" Pffft-
    Even the best trip planning wont help sometimes...
    What do YOU do?
  3. snowwy
    snowwy Road Train Member
    20,565
    13,288
    Jul 6, 2009
    whatever i want. cuz i'm not tied to a fuse.
    walstib and Raiderfanatic Thank this.
  4. dschmidt201
    dschmidt201 Light Load Member
    289
    109
    Jan 6, 2012
    Chicago
    If a shipper doesn't want you there you have no option but to leave try to find a parking lot close by or even a side street near the shipper if cops come and tell you to move you have no choice but to just get their name and possibly badge number and move on. I never really ran into this problem because I didn't care about hos rules I wanted to be home every night so I would drive however long it took to get home unless I was completely exhausted then I got a local gig and don't need to worry about ever being home
  5. fisher guy
    fisher guy Road Train Member
    1,993
    1,061
    Mar 22, 2009
    Ocala Florida
    off duty or sleeper time on duty not driving for 15 minutes for unloading if ur on elogs. if ur on paper and there is no time stamp then what is the problem?
  6. Jonrulerofearth
    Jonrulerofearth Light Load Member
    232
    340
    Sep 1, 2011
    Hueytown, Al
    Remove the fuse.....was it your company that told you to do that, or the shipper? If it was the company you work for, " FIND ANOTHER JOB, QUIKLY"! If it is the shipper, inform safety about it.
    That should be a huge red flag for you when someone tells you that. Good luck
    NavigatorWife and Chinatown Thank this.
  7. hors_19
    hors_19 Medium Load Member
    579
    294
    Jan 20, 2012
    Fennimore, WI
    Here is the question, are you running out of hrs as soon as you get there or while you are getting loaded? If you are running out of hrs as soon as you get there why not just stop down the road take a 10 and load after? If you are running out of hrs while you are there then hopefully its long enough to do a split sleeper and you have some drive time left.
  8. snowwy
    20,565
    13,288
    Jul 6, 2009
    isn't your statement basically the same as mine. in a more winded version though. :biggrin_25525:
  9. fisher guy
    1,993
    1,061
    Mar 22, 2009
    Ocala Florida
    find another job get real op's gotta man up sometimes u gotta do what u gotta do
    Ruthless Thanks this.
  10. Koolguy
    Koolguy Light Load Member
    88
    12
    Jun 9, 2012
    Trenton,NJ
    like fisher guy said. if u have elogs, hit u arrive once u hit the property of the shipper or consigne. then go to line 2 while u drive around or waiting to get live loaded. that what i do. so if i sit there long enough i can do a split break with my hours.
  11. cuzzin it
    cuzzin it Road Train Member
    3,561
    9,433
    Jan 19, 2008
    Berea, KY
