Running the Edge Insight 2 Monitor AND a an ELD
Discussion in 'Expediter and Hot Shot Trucking Forum' started by NightHawk365, Jun 18, 2019.
  1. NightHawk365
    NightHawk365 Light Load Member
    88
    214
    Apr 17, 2019
    North Idaho
    Been running on paper logs for Intrastate and Exempt Cargo, but will soon be running Interstate and have to run an ELD. Based on my understanding of the new laws applicable in December, this will have to be of the sort that plugs in to the ECM (OBD2) port. Unfortunately, this is also where my monitor system plugs in that reads all of my EGT, Boost Pressure, ETC. Does anyone here run both, and if so, how does it work?
    Thanks,
    JD
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Just get a splitter, it just plugs in and gives you two ends instead of one.
    86scotty, NightHawk365 and AModelCat Thank this.
  4. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    The eld plugs are made so you can plug into them.
    No worries
    NightHawk365 Thanks this.
  5. AModelCat
    161,291
    Splitter plug. The F550 I used to drive had one installed for the ELD so that we wouldn't have the ELD cable in the way.
  6. S M D
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Like so
  7. NightHawk365
    88
    214
    Apr 17, 2019
    North Idaho
  8. Aruiz1017
    Aruiz1017 Bobtail Member
    6
    Jan 27, 2019
    How’s it going boss… wanted to ask you are you still running the edge insight on your truck ?
