Running without resets
Discussion in 'Questions From New Drivers' started by CleverMoose, Jun 20, 2013.
  1. CleverMoose
    CleverMoose Bobtail Member
    Hi I've been trucking for about 2 years and have been on ele logs, but changed companys and now I'm on paper logs. My ? is how does running past the 8 day figure and still be legal?? I've heard people say (use it or lose it), what does that mean. Appreicate the help and examples would be great also :)
  3. Sublime
    Sublime Road Train Member
    1,529
    1,896
    Jan 18, 2013
    Twin Cities, MN
    Most log books from JJKeller explain a recap fairly well inside the cover.
  4. driverdriver
    driverdriver Road Train Member
    4,254
    5,283
    May 30, 2011
    midnight of the 8th day you get back the hours you used 8 days ago. If you were on duty for say 13.5hrs 8 days back then on the next day you could use'em
    1) 10 10 60 10
    2) 10 20 50 20
    3) 10 30 40 30
    4) 10 40 30 40
    5) 10 50 20 50
    6) 10 60 10 60
    7) 10 70 0 70
    8) 0 60 10 70 As you can see from the example on the 7th day you've used all your hours on the
    8th you enter 0 and count back 7 for your hour on duty last 7 days = 60
    Giving you 10 to use on the ninth day and from this point on for the next seven
    days you will get back 10hrs at midnight. Its called running on your recap.
    I hope this helps.
  5. russellkanning
    russellkanning Medium Load Member
    640
    142
    Jan 22, 2012
    Frost, TX
  6. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Not sure what they mean by "use it or lose it" other than it's not like AT&T's rollover minutes, where unused minutes from one week roll over to the next. What method is best (slow, but steady all week long, or balls to the wall, then reset) depends on your company, the amount of freight, and the average length of haul, how many appointment times you are forced to deal with, and your preferred way to run, given your options.
    airforcetoo Thanks this.
  7. sherlock510
    sherlock510 Road Train Member
    1,066
    1,058
    Jul 26, 2011
    Intercontinental.
    My reset ended on the 10th this month at noon.
    6/10 : worked 7 hours
    6/11 : 7.50
    6/12 : 9
    6/13 : 8.75
    6/14 : 9.50
    6/15 : 10.75
    6/16 : 11
    That's 63.5 right there, usually people take a 34 but you don't have to.
    Still can work 6.5 hours
    6/17 : 3.75
    6/18 : 9.75
    6/19 : 7.5
    Today : 9 hours avail.
    I usually would have reset already but have a load going home so no time for a reset.
    All while remaining legal.
    Hope that helped.
  8. BearGator56
    BearGator56 "The G stands for GOOD!"
    289
    53
    Apr 11, 2006
    Orlando, FL
    You can run from here until the end of time without a 34 hour reset as long as you don't go over 70 hours in an 8 day period.
  9. lilrich
    lilrich Light Load Member
    225
    76
    May 2, 2013
    phoenix AZ
    if you hit your 70 hrs on the 8th day exactly or close to than on the 9th day whatever time you ran in the 1st day of your 8 day week you can run that amount of time for the 9th day whatever hours you dont use on the 9th day that you ran on your first day get transfered over to the following days (1st day ran 8 hrs but n 9th day only ran 7 hrs 1 hr transfers over to next day) than on 10th day you can run what you ran on the 2 day + any left over from day 9 (2nd day you ran 8 hrs +1 hr from day 9 = 9hrs available for day 10) and if you took a day off on day 11 than whatever time you ran on day 3 and any extra hours left over from the other days will be available on day 12 + the hours you ran on day 4. and this carry's on till the next time you do a reset.
    If you take a day off during the week of your 8 days ie you get your 10 hr mandated break and take another 10-14 hrs off than you can have more time to run without having to run what you ran in the prior week i did say this above but trying to give another explanation on it as it can get confusing.
  10. iraqralph43
    iraqralph43 Road Train Member
    1,724
    2,901
    Jan 9, 2012
    run no more than 9 hrs... for the first seven days....on the eight day run no more 7 hrs...then repeat same cycle...week after week..you will never run out of hrs.....and never have to do a 34 hr reset
    Gunner710 Thanks this.
