I was looking at this dry van I want to buy today. It's 5-6 years old and it's been run up north a lot by the looks of it.
I've never purchased a trailer before so I don't know how much rust is too much or if it even matters.
The box and floor are good to go for sure.
If I bought it I assume I could pull the wheels and have it sand blasted and repainted.
What do you all think?
Thank you
Rusty undercarriage dry van
Discussion in 'Ask An Owner Operator' started by Edjahman, Jul 16, 2020.
I suppose that it is.
I think that I'm just nervous about buying a used trailer.
Most of the paint is gone from the hubs etc.
I mean it's pretty rusty but for something that came from the northern part of the country it's probably to be expected. -
I suppose that if things have rust straight on through things then it's time to worry.
Like rust making holes in things etc? -
All equipment eventually rusts. You need to really get under it and do a thorough inspection. Make sure the cross members aren't so rusted that they will failEdjahman Thanks this.
Yeah I was doing some of that today and I'll be going back in the morning to do a better inspection.
Thank youbad-luck Thanks this. -
My trailer was that way. More rust than I would prefer. It’s been good. Depends on whether it’s just surface or if it’s losing a layer. The bogies will crack eventually from rust. My last trailer did that.
Dave_in_AZ and Edjahman Thank this. -
One thing to look for, is rust behind the side rails. The aluminum corrodes, where the cross beams are riveted. Starts with rust jacking, broken rivets, bubbles, and pin holes in side rails. Aluminum turns into a white powdery corrosion from dissimilar metals.
Yeah it looks like just paint loss really. I'll get the microscope out tomorrow though.
Thank you
Thank you. I'll bust out the microscope tomorrow and see!
Appreciate the feedback!Dave_in_AZ and Rideandrepair Thank this. -
Take a screwdriver or something and stab the frame in a bunch of spots and make sure it's not too bad. Plan on having to throw new brake cans, possibly drums, and shoes while you're at it, on it. I've seen them rusted about half gone from the outside.Dave_in_AZ and Edjahman Thank this.
