Salt Haulers! Pls Help
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Chevyho, Sep 19, 2015.
  1. Chevyho
    Chevyho Medium Load Member
    350
    55
    Dec 13, 2013
    My company has an opportunity to haul coarse road salt. We have 35' tridem aluminum end dumps, I am curious as to what the salt weighs per cubic yard because I want to be sure we can fit enough to max out our 31 ton payload capability. Also we use mesh tarps, which work fine for sand but Ivr never hauled salt. Any information is greatly appreciated.
  3. str8t10
    str8t10 Medium Load Member
    323
    415
    Apr 25, 2015
    Rochester,ny
    My company hauls it too! We have tri axles with 1 drop axle to make a total of 4. Good to 117k gross so my rig can take almost 40 ton. Anyways bulk road salt weighs about 1 ton per cubic yard. We use canvas tarps to keep it dry but I think mesh will be fine in dry conditions. Hope this helps
    Chevyho Thanks this.
  4. Chevyho
    350
    55
    Dec 13, 2013
    How much payload can you actually get in your trailer? And what are your dimensions? We are 35' long, 8' wide and 5' high sides.
  5. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    Salt doesn't pay very good.
  6. Chevyho
    350
    55
    Dec 13, 2013
    Its a tender so ill put what its worth to me. I know what rate was the past 2 years and rates were decent. Im in canada.
  7. Cat sdp
    Cat sdp . .
    20,858
    72,036
    Apr 8, 2012
    Orion's Belt
    You can fit 31 tons in that trailer no problem....
  8. str8t10
    323
    415
    Apr 25, 2015
    Rochester,ny
    Our trailers are 40ft x 8.5 wide X 6 inside height. I don't know what the yardage is on the salt but we max out our permits. Also I'm a company driver so I get paid by the load so it's always different depending on where it's going
    I don't know what the boss is making
  9. str8t10
    323
    415
    Apr 25, 2015
    Rochester,ny
    It does when certain areas get a lot of inclement weather and our shop is 20 miles from a huge salt mine. When they're running low and need it there asap the price goes up. I know this because we make one run that's about 150 miles. Company drivers get 50 cpm. When they call and they're out we usually make 100 to 125 for the same run. The boss is generous enough to pass some of the extra profits along to us.
