Samlex 1500 inverter problem
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Albert Wesker, Oct 10, 2011.
  1. Albert Wesker
    Albert Wesker Light Load Member
    69
    11
    Sep 17, 2011
    My truck got an APU and an inverter called Samlex 1500, I can use it for like a couple of hours, then it will not work, it flashes red light and no power is drawn, when it works, it has green light that stay lit, then after a couple of hours it will go flashing red for like 8-10 hours then it will work again for another couple of hours, why is it doing that? I mean I got an APU which can constantly gives it power, is it pre-programed to do that because it thinks that I have no APU? If so how can I change it so it will run all the time?
  3. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    It would be great if you could tell from a manual what the flashing red light meant! Is it low voltage, high temperature, too high a load? Those are the 1st 3 that come to my mind.
  4. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    http://www.samlexamerica.com/customer_support/pdf/Manuals/SA-1500_Manual_Mar2010.pdf
    last page is a phone/E-Mail.
    Thanks,
    Mark
