San Diego plane crash
Discussion in 'Other News' started by Chinatown, May 23, 2025.
  1. Chinatown
    Chinatown Road Train Member
    77,805
    184,792
    Aug 28, 2011
    Henderson, NV & Orient
    Bing Videos
    Early details on San Diego plane crash that killed multiple people
  3. 7speed
    7speed Light Load Member
    146
    340
    Jan 11, 2025
    1/2 mile visibility….200’ ceiling…why even attempt this?
    mjd4277, JC1971 and Flat Earth Trucker Thank this.
  4. JC1971
    JC1971 Road Train Member
    2,684
    9,821
    Jul 29, 2013
    Southwestern U.S.
    Runway lights weren't working, either. What could go wrong?
  5. mjd4277
    mjd4277 Road Train Member
    14,741
    45,405
    Oct 4, 2015
    Fitchburg,MA
    Something tells me that this may have been a classic case of “Getthereitis”-which has caused MANY an aviation accident!
    JC1971 and 7speed Thank this.
  6. 7speed
    146
    340
    Jan 11, 2025
    Or overconfidence...."Yeah, I've flown this route many times and in similar weather. We're good."
    Wonder how many hours he had in that type aircraft?
    His alternate had slightly better visibility but only a 300' ceiling. Surprised he didn't have another alternate or just turn around.
    Wonder why its not equipped with a flight data recorder. Because it's a private jet? :confused:
    mjd4277 Thanks this.
  7. Moose1958
    Moose1958 Road Train Member
    15,296
    33,965
    Dec 17, 2010
    Williesburg, Virignia
    This happened at night and after a long cross-country flight. The ASOS was out of service. That Cessna Jet was not even authorized to make that approach. If you take a look at the bottom of this approach plate, you will see that under the category C aircraft are the letters NA. The Cessna Citation is a Category C aircraft. There was nothing wrong with the runway lights. They are pilot-controlled by "keying" the push-to-talk button rapidly. The pilot was not authorized to fly that approach in those weather conditions. On the glidepath is a high elevation with power lines. The aircraft struck those lines.
    Getthereitus is deadly in both Aviation as well as Trucking. That pilot should have while refueling in Kansas should have gotten a good weather report and just stayed there that night.
    The Google Street View is from a park about a 1/2 mile from Sample Street where the plane crashed. In the distance, you can see the powerlines that the plane clipped.
    JC1971 and mjd4277 Thank this.
  8. mjd4277
    14,741
    45,405
    Oct 4, 2015
    Fitchburg,MA
    Private jets with a capacity of 10 or more passengers are mandated to have flight data recorders. But because this particular aircraft type (Cessna Citation II)only seats 6 to 8 passengers it may have been exempt.
    https://nbaa.org/aircraft-operation...orders/flight-data-recorder-fdr-requirements/
  9. Moose1958
    15,296
    33,965
    Dec 17, 2010
    I did not check, but I think the Cessna Citation flown in this crash is approved for single-pilot operation. I doubt a ####pit voice recorder would give any information other than maybe an oh (redacted) near the end. The ATC displays and the data blocks already give us the altitudes and speeds. One piece of information the NTSB could use was the Jets altimeter setting.
    In the approach plate link I posted in my last comment, look toward the bottom right. Just above the category A B C D. You see a line sloping down from right to left with marks on it named "Nesty" "Penyy", and "Palos" next to them, you see numbers with lines under them. Those lines are minimum altitudes at those "fixes". The pilot was flying an approach that category of aircraft was PROHIBITED from flying in that weather. Also, the pilot DID NOT have the current altimeter setting for that area. Transponders on the aircraft automatically send altitude data for a standard 29.92 pressure, and the ATC system converts that to the current setting of the major airport in the area. This altitude displayed on the ATC screen may or may not be the actual altitude set in the jet's altimeter. Just a series of mistakes going back to Kansas when the decision was made to continue.
    mjd4277 and 7speed Thank this.
  10. JC1971
    2,684
    9,821
    Jul 29, 2013
    Southwestern U.S.
    Or, they could have landed in Orange County and taken a 1 1/2 hour limo ride to San Diego depending on what the weather was there. Like you said, a case of getthereitis.
