Sandblasting truck frame
Discussion in 'Trucks [ Eighteen Wheelers ]' started by fortycalglock, Nov 30, 2011.
  1. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    I'm going to be sandblasting my frame rails in a month and I am looking for some tips. I'll have some decent scaring, should I fill it with something like fiberglass, bondo, etc. A friend suggested spraying it with truck bed liner. What are your thoughts? I'm looking for any tips on metal prep etc.
  3. Displaced Yooper
    Displaced Yooper Light Load Member
    152
    49
    Oct 18, 2010
    Detroit, MI
    Aluma-Glas is good, body lead is better.
    Note of caution: If you use one of the rust inhibitors (such as Extend from Loctite), many body fillers will NOT adhere to it.
    Best bet after blasting is to use a good epoxy-based sealer/primer.
  4. rjones56
    rjones56 Heavy Load Member
    823
    486
    Jul 15, 2008
    staunton va
    I would use something other than sand-you don`t want all that grit in any moving part.Also you can probably get some good tips from an body shop that restores old cars.
  5. Licensed to kill
    Licensed to kill Heavy Load Member
    830
    2,434
    Dec 31, 2010
    Alberta
    Coating a frame with "truck bed liner" is a REALLY bad idea. Endura or Imron paint are good choices.
    Cabover Mike Thanks this.
  6. 7060
    7060 Light Load Member
    55
    5
    Oct 2, 2010
    Chassis-Saver is good stuff I think, just don't breath it
  7. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Instead of sandblasting, would soda blasting be a better option? At least I have heard of that being used when people have done cab off restorations. Or is it basically the same thing?
  8. fortycalglock
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    Soda blasting uses baking soda, but I have access to an industrial sandblaster, so that's what I'll be using with a trailer compressor. My main issues are around the drives, and they should be off the truck at the time anyway. Just looking for tips really. One guy recommended using Ospho after blasting to inhibit rust.
  9. Don2WS
    Don2WS Medium Load Member
    306
    26
    Feb 26, 2010
    Sturtevant WI
    i blasted mine in May i used aluminum oxide, silicon carbide and some pumice my neighbor does a lot of work for cat and case so he helped me a lot along the way. i used plenty of duct tape around seals since i didn't pull off the rears. i used case epoxy paint and so far its held up pretty good
    fortycalglock Thanks this.
  10. LSAgentOZR
    LSAgentOZR Road Train Member
    2,043
    1,354
    Nov 1, 2011
    Nashville, TN
    I'd spray it with bubblegum and rubber cement!:biggrin_25525::biggrin_2559:
  11. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    In the areas, like the steady bearing especially wrap it with towels and duct tape. I always recommend replacing all zerts after the job is done and it is painted. Cover the mirror even if you are twenty feet from then. The brakes, using a pressure washer in the slot of the backing plate slowly move the truck so the wheels do a 360 degree turn, to clean out the brakes.
    The I use tremclad, but you need multiple coats, and do it right away after blasting, pressure washing, and blow drying.
    I use cheap sand, for the bigger parts Cabs use the soda.
    Cabover Mike and VisionLogistics Thank this.
