Sapp Bros isn’t playing around
Discussion in 'Truck Stops' started by Long FLD, Sep 14, 2019.
  1. Long FLD
    Long FLD Road Train Member
    12,177
    50,355
    Mar 4, 2015
  3. Demonrogue
    Demonrogue Light Load Member
    250
    78
    Sep 21, 2013
    Carson California
  4. xsetra
    xsetra Road Train Member
    5,134
    7,036
    Aug 21, 2011
    Similar
    The internet loves Wisconsin truck stop’s solution for selfish parking job
    What do you think about this?
    By
    Ashley
    September 12, 2019
    A Wisconsin truck stop’s Facebook post about how they dealt with a truck driver’s self-centered parking job has gone viral.
    On Thursday, September 12, Hixton, Wisconsin-based truck stop Hixton Travel Plaza shared a Facebook post about their solution to a parking problem.
    They wrote:
    You want to park like a @$!%# and block two pumps while you take your break, then refuse to move? We’ll make sure you sure you sit a bit longer (he was ready to leave after we did this by the way).
    Please treat your fellow drivers with respect while on our premises, that’s all we ask.
    The post received more than 1000 reactions and 400 shares in just three hours.
    While a few Facebook commenters pointed out that the truck stop could’ve just called for a tow truck, most were delighted with the solution.
    RELATED ARTICLES
    Woman gets 5 years for embezzling $800K from trucking company
    September 12, 2019
    Truck driver killed when his big rig plunged off I-5 bridge
    September 12, 2019
    Police: Truck driver ‘didn’t notice’ slowed traffic before causing deadly I-65...
    September 12, 2019
    Copyright © CDLLife
  5. tucker
    tucker Road Train Member
    12,647
    40,423
    Jun 13, 2008
    IN
    That’s why you leave the 5th wheel all the way back.
    That way you can turn the steering wheel all the way to one side, slide the fifth wheel forward, spin the steering wheel fully the other way and drive off into the sunset while playing Dixie on the air horn.
    88228822 and Short Fuse EOD Thank this.
  6. MACK E-6
    49,447
    232,303
    As opposed to simply not parking like a schmuck? o_O
  7. tucker
    12,647
    40,423
    Jun 13, 2008
    IN
    Fed Ex did have doubles, I guess he could have broke it down and baked it in to a couple of spots.
  8. D.Tibbitt
    152,276
    Nothing makes this post so refreshing than to see a fed ex idiot the justice he #### well deserves. Im sure he has held up more than a couple fuel islands in his career as well
    jon69, homeskillet, Tall Mike and 7 others Thank this.
  9. Long FLD
    12,177
    50,355
    Mar 4, 2015
    I wonder how many fuel pumps are blocked at any given time across the country by Fedwrex taking their 30? The FMCSA should give them an exemption so they can just keep rolling instead of blocking everything up.
    An old friend of mine used to drive for a Ground contractor and would always take her 30 at the same place and park at the pump. When I suggested a place about 20 miles up the road with pull through spots she said she didn’t like that place and would rather block a pump to stop at her spot. So if people like that have to start paying to leave I don’t have a problem.
  10. Lyle H
    Lyle H Road Train Member
    1,291
    2,937
    Apr 16, 2014
    Maybe he was practicing the parallel parking portion of the next truck rodeo.
    Snailexpress and D.Tibbitt Thank this.
  11. bzinger
    bzinger Road Train Member
    16,615
    65,955
    Dec 10, 2014
    omaha , ne
    I woke up at the pilot in Greenfield ind at 5 this morning to car hauler blocking me in sleeping .
    Tap tap...he politely moved .
    It's the arrogant ones that piss people off .
  12. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,140
    Mar 5, 2016
    White County, Arkansas
    Drop pintle hook on second trailer back up 3 feet over it if you can do it. That should be enough space to start working your wheel back and forth to get out. When you have the front end free or almost so lean on one corner of that jersey barrier, estimate wieght about 3 ton, add horsies in granny low.
    THUMP. back up attach your second pup and roll out.
    A very long time ago I had a compound pulley with 10 one foot wheels on it. Hook chain to that, hook other end to a very powerful anchor and start winding. You can move 15 ton deadweight sliding a little on the ground if done gently. Just not very far at a time.
    I don't think truckstop would take kindly to such a effort to corner out one of those.
    Dave_in_AZ Thanks this.
