Saw an interesting transmission system in use.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by PackRatTDI, May 22, 2007.
  1. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    I went with my dad and students/staff on a trip to Mexico. For a couple of days we rode in a charter bus, an Irizar Century with a Scania chassis. The transmission was a Scania fully syncronized 7 speed with what is called "Comfort Shift". It's an electropneumatic gearshift system with a automotive like shift knob mounted on a box attached to the drivers seat with a cable containing airlines and electric cables to connect it with the transmission, meaning there is no direct link between the transmission and the gearshift.
    Here's an example:
    Every time the driver shifted, you could hear the air system from the shift box, which sounded like when you make a range change in a 10 speed. Anyways, the most interesting part is that the transmission will not shift until the clutch is depressed. The driver can preselect his shift, then when he's ready, hit the clutch, thereby shifting the transmission. Consequently there is no way that the transmission could be knocked out of gear, or in gear when the bus was parked and the transmission was in neutral. In fact he showed us while underway by rowing through several gears at highway speed. Nothing happened without the clutch being depressed.
    Volvo offers a similar system, called "Easy Gear Shift". I wonder if these kinds of shifting systems had been offered in the US if that would have made manual transmissions more popular in motorcoach service. Now they've completely dissapeared as an option, it's all automatic.
    x1Heavy Thanks this.
  3. sano
    sano Bobtail Member
    43
    5
    Sep 24, 2006
    Indiana
    Neat! Thanks for sharing! :D
  4. driver4015
    driver4015 Medium Load Member
    529
    189
    Jan 28, 2008
    Bend ,Oregon
    sounds better than the 5x5x4 I used to drive,Hauled logs in the summer and heavy equiptment when the woods were down.
  5. Scott0101
    Scott0101 Bobtail Member
  6. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    I have seen that ComfortShift on MAN trucks 5 years ago in Russia. Another eurojunk.
  7. kranky1
    kranky1 Road Train Member
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    It may be worth noting that there is also no way to put it in a gear if the black box full of wonderful technology doesn’t complete a shift. Sorry, things controlled by boxes with wrist sized bundles of wire coming out of them have no place on our highways. It used to be pretty simple, if you couldn’t drive the truck, you didn’t get to be a truck driver. I personally felt a lot safer on the road when the trucks themselves kept unsuitable individuals out of them. It used to be the no-minds in cars, now my biggest fear is the other trucks.
    AModelCat Thanks this.
  8. RDTrucking
    RDTrucking Light Load Member
    53
    65
    Jul 24, 2018
    Some day in the not so far away future someone is going to make the post “saw an interesting transmission system in use” and they will be talking about a manual trans.
    AModelCat and Gearjammin' Penguin Thank this.
  9. Russian Rabbit
    Russian Rabbit Road Train Member
    1,701
    1,633
    Jan 3, 2016
    i saw, and actually drove and "interesting" transmission all last week.
    This transmission actually backed up exactly when and how i wanted to with no lag or jerkiness (and without damaging kingpins). It also moved forward and accelerated exactly when and how i wanted, smoothly without jerking.
    Eaton Roadranger 10 speed, i think it was......................:rolleyes:..........:mad:
  10. Russian Rabbit
    1,701
    1,633
    Jan 3, 2016
  11. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    UGH.
    Most of the buses Ive driven have that long rod going all the way back to that blessed transmission. You can gain quite a bit of knowledge of what the driver is thinking by what he does with the #### thing versus the overall situation (Deep snow, grades and his engine power situation at that moment)
    If I can sleep on a bus (Which is really really rare, that is the bus driver you want to keep forever)
    This fly by wire stuff is interesting. But all those gears. Ugh. Why not stick to 3 or 4 really big tall gears and wait a minute until the engine gets up there enough to shift them.
    All these modern shifting leads me to one thought. They don't want engines to turn worth a ####. No more 2300 RPM, No more 1200 to 1600, they would make it one RPM if they could all day long with no power to get up and go and no pull to get over anything. SHEESH.
