Scale Ettiquette
Discussion in 'Questions From New Drivers' started by goblue, Mar 30, 2013.
  1. goblue
    goblue Road Train Member
    1,586
    789
    Dec 23, 2012
    Grand Prairie, Texas
    Just home from my first solo trip out with Roehl. I have three particular questions regarding scales and welcome any scale advise that you may consider relevant.
    First experience was Illinois. Got the read light on my prepass and drove in. Arrowed to the left lane, There was a tank truck in the right land scale with the red X light. Pulled onto the scale and stopped. Green arrow just remained on. Heard guy behind me hit the horn and DOT guy next to tanker waved me on so I just moved on. I had been to a CAT after I picked up my load and new that I was way under and weight issues. So the question is how do I really know it is good to go? do I have to wait for any particular signal?
    Second experience was Ohio or Indiana, can't remember for sure. Went into scale and there were signs along scale place drives here with arrows. I went through the scale at about 5MPH..didn't stop just kept rollling and moved on. Was I supposed to have come to a complete stop? Again, all green arrows, no signals to stop like a red and then a green.
    Third was heading into Kentucky from Tennessee. Red light from prepass and go to enter scale and its full to the highway. See a bunch of trucks diving for it and then just heading on passed it. I have seen the signs saying to continue on if ramp is full but don't recall that sign being posted before this scale. I just kept going with the flow and chose to be safe and not get in the way of traffic. Looked to me like everyone was getting called into the scales here. Did I do the right thing?
    I hit some scales with my trainer when I was out with him but never really got a full detailed explanation or rule book so to speak. Also hitting new states that I did not see during training. Thanks for your advice in advance.
  3. Balakov100
    Balakov100 Road Train Member
    3,937
    2,636
    May 10, 2012
    Temple, TX
    Every Scale(master) is different.
    If there are arrows directing you whether to go over the Scale or bypass, follow them.
    The Stop Lights in front of the building, often times they don't use them.
    goblue and MJ1657 Thank this.
  4. RickG
    RickG Road Train Member
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    Never pass a scale with a full ramp unless there are signs saying so . Every state is different . MI has signs saying to line up on the shoulder . TN has a line on the ramp with a sign saying o.k. to bypass if trucks are lined up to there .
    If a red light or stop sign didn't come on when rolling across a scale I'd continue to roll slowly . Some scales have signs just saying to slow to 5 mph across scales . You have to be observant at each scale .
  5. pattyj
    pattyj Road Train Member
    22,474
    20,136
    Jul 19, 2008
    Sioux City,ia
    First off when entering a scale ALWAYS make sure your window is down.Most have speakers right there will either tell you to pull around back or go ahead and go.If you're on the scale too long while waiting for the DOT to signal you,thats not a good sign.When entering the scale,keep an eye on the lite not the DOT,they don't like that.Ive seen more drivers looking at the dot rather then focusing on the lite.If your entering a scale on a green lite,go very slow like 3 mph,once that lite turns red STOP then proceed slowly off the scale when it changes green unless he tells you to pull around back.When you proceeded slowly thru the scale without stopping and the dot didnt say anything,you did fine.Alway weigh your loads when in doubt before entering any weigh station.You dont wanna give the dot a reason to inspect you if youre overweight.Scales that are full usually you'll see a sign that says ok to bypass or the dot will turn on the sign that says scale closed.Try not to get nervous when entering a scale,dot can sence that and may have you pull around back just for that.
    jbatmick, goblue, davetiow and 2 others Thank this.
  6. Driver of the year
    Driver of the year Medium Load Member
    442
    249
    Sep 28, 2012
    Tampa FL
    When i was over the road, i noticed that alot of scales you just roll at 8 mph and if no red light, keep going slowly back to the highway.
    goblue, mje and 48Packard Thank this.
  7. pattyj
    22,474
    20,136
    Jul 19, 2008
    Sioux City,ia
    Guess it depends on the scale.I have entered scales at 30 mph with a dot outside waving you to keep going.Its like whats the point of even going thru,lol.
    mje Thanks this.
  8. Zen Trucker
    Zen Trucker Road Train Member
    1,038
    1,177
    Aug 9, 2012
    Yeah, goblue, it is frustrating when you first start out knowing what the correct procedure is since it does seem that every state is different. The advice above is good. You just have to be ready for anything. I like to stay just a bit left as I'm coming in to see what the drivers ahead of me are doing. Are they rolling across the scale or stopping.
    A while back, MO stopped me ON the scale and told me to bring my paperwork in. I couldn't believe I heard them right with the line of trucks behind me so I asked to make sure I heard them right. I had and I guess my questioning got me a Level 2. :biggrin_2556:
    Needless to say, the line was considerably longer by the time they got done entering all my info in the computer.
    davetiow Thanks this.
  9. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Windows down, radios off, inside of truck spotless and uncluttered, neutral expression. MAINTAIN THE SPEED THAT'S ON THE SIGNS. Don't go faster, and DON'T GO SLOWER, unless you're going to smack into the rear of the idiot in front of you. If you're too far off the ramp speed, the WIM scale won't always give an accurate weight and you'll get directed to the scale instead of the bypass. Follow the arrows, only stop on red. Follow the instructions on the signs at the scale - most want you to wait for the truck in front of you to clear before you move on. Most also want a complete stop before rolling on to the scale. Roll to a stop if the light is red or goes red, don't slam the scale by stopping too hard. Once you're stopped, release your brakes; the scale should be level and you won't roll, and that will allow your wheels to roll free so that the scale will read accurately. Some scales require you to turn on your lights, and have signs to that effect. If there are no signs to that effect, I will leave my lights off during the day. No need to give them a reason to pull you around if you've got a light out.
    I don't have prepass, so I pull in to all of the scales. If I have to slow to a dangerously slow speed or actually stop on the highway in order to get into the decel lane because of the line of trucks waiting, I always bypass. I've never been chased down for this.
    That's about all I can think of.
    g.o.a.l, Zen Trucker, mje and 6 others Thank this.
  10. goblue
    1,586
    789
    Dec 23, 2012
    Roehl wants us to scale everything in phase 3 so I do, we are reimbursed for them. In each instance I did know I was within weight guidelines. In hindsight I probably should have just got in the end of the line in Kentucky, just as far right as I could. I really did not feel bad about it because others were trying to make the line but giving up and going on by. From my recollection, the Tenn. scales had the bypass when full signs but I dont think the KY scales had that. New driver, just trying to do the right thing. I work local LE for 26yrs prior to driving, I have not fear of them just don't have the years in commercial driving yet.
    mje and The Challenger Thank this.
  11. MJ1657
    MJ1657 Road Train Member
    7,521
    50,151
    Jan 28, 2012
    Isanti, MN
    It is frustrating when they don't have any signs indicating what they want you to do.
    Sometimes almost feels like they're trying to set you up to fail
