scangauge
Discussion in 'Ask An Owner Operator' started by TruckerPete1990, Apr 19, 2015.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,377
    Jul 16, 2012
    Bentonville Arkansas
    I'm looking at the scangauge for my truck. My question is the company I'm going to require me to use a eld that plugs into that port. Anyway to run them both?
  3. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    You can run both. They all plug into each other.
    TruckerPete1990 Thanks this.
  4. TruckerPete1990
    8,623
    5,377
    Jul 16, 2012
    Thank you!
  5. Old Man
    Old Man Road Train Member
    4,597
    13,470
    Apr 3, 2009
    Oklahoma City, OK
    You don't need the KR edition SG, just a SG diesel, on the net or from motorhome dealers.
    blairandgretchen Thanks this.
  6. drvrtech77
    drvrtech77 Road Train Member
    14,397
    139,291
    Mar 20, 2010
    I bought mine at camping world.
  7. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I've seen them at Autozone also.
  8. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    The KR edition's biggest feature is the MPG. Instead of updating every second it averages it over like 15 seconds so your not chasing it. And I'm not talking about the average MPG
  9. ipogsd
    ipogsd Heavy Load Member
    977
    515
    Jun 13, 2012
    IMHO you buy a scan gauge to primarily save fuel, the KR edition helps you due this with the current MPG be averaged over 8 seconds, which helps you tremendously with your goal. Spend the extra 50 on the KR, you'll be glad you did.
  10. TruckerPete1990
    8,623
    5,377
    Jul 16, 2012
    I just ordered the kr one.
  11. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    I got the x-gauge codes from scan gauge for my 2013 DD15, I usually have it set to monitor my after treatment system. I watch the DPF temperature, the DOC temperature, the NOX sensor and the DPF differential pressure.
    In the winter I would see that it did an active regen almost daily, 3-4 minutes at 1000F. And a passive regen almost weekly, 2-1/2 hours at 800F. And once a month an active regen, 1140F for 20 minutes.
    In the summer it hardly ever does any regen as climbing large hills the DPF would get up to 770F, so basically I got a free passive regen anytime I climbed a large hill.
    So I use my scan gauge for piece of mind as to how my emission system is behaving.
    ipogsd Thanks this.
